I have this problem....
Everytime when I try to encode Avi files to Mpg (or Mpv or Mpa), MainConcept will says....
Error: BUFSTRM:Unable to open file for writing.
This happened to all of my avi file...I didn't have this problem when I authoring my 3 anime DVD in the first time. And I didn't touch any of the setting exept for bitrate and expect ratio..What is the problem here?
I try to use Tmpgenc..then it says............Unable to convert....bla..bla...(I dont remember)...The second time, I try to create MP2 file..It did work but no sound will come out from the Mp2 file...
I create Wav file using VirtualDubMod usiing the same AVI....It works but the WAV file is small...Just 23MB for 25 minutes....128kbs and 48000khz.....But the sound came out normal...I convert it to AC3 and the filesize is 70MB. The last time I creating Wav file using differrent AVI but same length, the file is 65MB...Convert it to AC3 and it shrinks to 24MB....Is this normal?? I dont think it is...Help please??
Thanks..
Do you know why people mostly use Mac in their office?
Because a lot of stress can lead people to jump off the "Windows". -
Try using virtualdub (regular) or virtualdub-mpeg2 for extracting to WAV - your 25 min WAV file should be around 280MB by my calculations.
If in doubt, Google it.
Unable to encode whole video
By Egotomb in forum Video ConversionReplies: 5Last Post: 4th Apr 2012, 14:57 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 04:47 -
Mainconcept MPEG-2 / H.264 refuse to encode interlaced footage
By Colmino in forum Video ConversionReplies: 0Last Post: 2nd Jul 2008, 15:23 -
TMPGEnc Xpress, MainConcept, H.264 and QuickTime Compatibility
By PuzZLeR in forum Video ConversionReplies: 6Last Post: 27th Oct 2007, 04:05 -
TMPGEnc Author Version 2.0 - Unable to make a DVD with a motion Menu
By tug_hill2 in forum Authoring (DVD)Replies: 5Last Post: 28th Sep 2007, 00:37
