I wonder what program is used to produce advertesting clips with no live objects, like advertesing for detergents, mobile telephones, chocolate……., when they are rolling and spining around, pomping, showing their all three dimensions, rolling and flying text and so.I want to start to learn making such video clips but I don’t know where to start.
I know about 3D Max 7 and Adobe After Efects but they are to tough for me.
Maybe some other simple program for beginners will help.
Regards.
QUALITY HAS A NAME
Blender is good , but if you need to create 3d model's , then also consider wings3d .
Then there is fly3d210 ... game engine which is really quite basic , though just like any program with so many function's it too take's time to get the grip's of .
Also good old free gmax . -
A program that I tried a few years ago was called Simply 3d.
As I recall it was easy to use. I think I was using it with Windows 2000.
You can find the program occasionally on ebay. -
The gold standard for much commercial/movie work is Autodesk's Maya. There is a free "Personal Learning Edition" available (watermarks the images, some output limits) that would be fine for learning purposes. Full commercial Maya is $$$$$ (don't ask -- you can't afford it). But the learning curve is very steep, as it will be for any decent 3-D package. Something I used a little years ago was Asymetrix 3DF/X, which you might be able to find in the used S/W market. Much easier to use, but much more limited, as well. I don't know whether it will run under 2K/XP. Probably, but I've never tried it.
Steve -
Blender
Ulead Cool 3D
Bluff Titler (mainly for text only)
All found by typing "3D" in the "Tools" search...
I subscribe to www.download.com, and their last newsletter mentions Google Sketchup.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Easy subtitle creation program
By txl in forum SubtitleReplies: 1Last Post: 7th Jun 2011, 06:59 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
5.1 AAC Creation
By doomgaze3 in forum AudioReplies: 8Last Post: 17th Mar 2009, 12:31 -
help with dvd re-creation
By souleye in forum Authoring (DVD)Replies: 0Last Post: 21st Jan 2008, 20:12 -
DVD creation..
By Fathead31 in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 00:46
