What resolution is TV shot at?
More to the point, should I buy Farscape / Star trek DS9 / etc. On dvd (for way to much money) or should I wait until the HD versions come out on HD-DVD / Blu-ray.
I know that things that are filmed (movies) can benefit from the move to HD but does "video" TV benefit?
-a-
Results 1 to 16 of 16
Depends on the show and their producer(s). It's a mix. Some are shot on film and then transferred to video for broadcast. Some are shot hi-def and down-rezzed to SD, some are shot SD. It'll likely be a mix for some time to come (although likely there'll be more HD as time goes on, and less SD and film).
Things shot on film (16, 35,super35, 65, 70mm) or on HD can benefit by going to BD/HDDVD, depends on the quality of the master/transfer/compression. SD wouldn't really benefit.
Scott -
Thanks for the reply,
Is there anyway to know for the two or three shows I'm thinking of buying?
Any guidelines, like:
old stuff (pre 1970 is on film)
1970-92 would likely be on video SD
and new stuff would be HD
just wondering.
Is it the same deal for animation? -
Farscape upto and including season 3 I think was shot on PAL video (it was filmed here in Australia). Best quality would probably be to get PAL Australian DVD's. HD isn't going to gain anything. Season 4 and The Peacekeeper Wars are different. Could be they were shot HD. I don't know. Anyway season 1-3 I think are fullscreen at least and season 4 and PK wars are WS.
DS9 would have been shot on NTSC video probably.
Most current TV I would imagine is shot on HD digi cams since it is cheaper than film and easy for HDTV. Older show would be shot on film or video depending on the budget, etc. Like Enterprise I think they started out with film and finished with HD digital. -
A series like Star Trek DS-9 would have been shot on 35mm film but edited and effects done in SD digital video (Rec-601 720x480i/576 4:2:2:4). They usually separately created NTSC (720x480i/59.94) and PAL (720x576i/50) resolution masters. To re-edit for HDTV, they would need to transfer the needed scenes from film at HD resolution and recreate the effects sequences in HD.
In recent years, this kind of series would be edited in 1080i or 720p HD with SD NTSC and SD PAL versions created off the HD masters. Most often 60 Hz. and 50 Hz versions are separately edited.
There is a very recent trend for TV post production to be done at 24fps HDTV (1920x1080p/24) the same resolution as HD/BD DVD. A single 1080p/24 master can be easily converted to 1080i/480i at 29.97, 720p/480p at 59.94, 1080i/576i at 25 or 720p/576p at 50.
AVID and others released 24p versions of their editing software (intended for TV production) a couple of years ago. Over time the only differences between TV and theatrical film editing will be native resolution (1080p vs 4kx4k). Currently, many effects processes can be done realtime or near realtime at 1080p, but require extensive non-realtime computation at 4kx2k or 4kx4k.
http://www.zerocut.com/tech/p24.html
http://www.avid.com/solutions/postproduction/hdsolutions.asp
http://www.avid.com/resources/whitepapers/hdworkflowWP3.pdf?featureID=886&marketID=1 -
Star Trek: Enterprise is the only Star Trek show that was ever shot in HD. I know the 4th season was. Possibly the 3rd season, but I don't know. I don't believe seasons 1 and 2 were.
Paramount has no plans at present to release any Star Trek shows in any HD format. They are probably waiting to see if either format survives and sells enough copies to justify the cost and time for them to release the shows in it.
Animation is always (as far I can tell) in either 480i or 480p, which is a valid format for HD, but it's compatible with current standard definition DVD. For example, I believe the Simpsons broadcast in 480p, which is a valid resolution for HD, but it's not really any better than current DVD technology. Malcolm In The Middle, on the same network, broadcasts in 720p.
I can't answer your question about Farscape as I'm not a fan, but I would guess that anything recorded prior to about 2003 is most likely not HD. -
Don't get caught in the trap of assuming that the way it is shown at broadcast is the way it was shot (or even edited)!
Don't know what animation apps a show like the Simpsons uses, but I would guess that it would be a combination of specialty animation/rotoscope/tweening/onionskinning apps, like Moho, and compositing apps, like AfterEffects or Combustion. A vector-based app like Moho is, in essence, of infinite resolution. It only has a stated resolution when you export the final show. AE/Combustion uses vector and bitmap graphics, but AE at least can have a HUGE canvas size (IIRC, 32000x32000 pixels?), so it all depends on what quality level the producers want, and what infrastructure they can afford to support.
Also, back before most animation was done on computers, it was drawn by hand on cels (roughly 8"x10") and photographed frame-by-frame with a 35mm film camera (so film resolution) or HD camera (HD rez), and then posted and then exported/converted to the size required for broadcast or distribution.
I wouldn't be at all surprised if they worked at 2k or 1080p settings, and then just downrezzed for broadcast.
Scott -
Well don't forget the new hd/bluray players will have upscaling ability for the current dvds so yours will look better (a little, its not magic).
So you have the risk/reward issue. You can buy them now and enjoy them at the "lower" resolution or wait and go without until you pick between bluray/hddvd.
Personally DVD is enough for me since I don't have a hdtv set.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
..and the other side of the coin to this, is how they will re-process them.
I mean. They may or may not be IVTC capable. Just like the shows are now:
** DS9
** Voyager
** ST-NG (next generation)
These will not IVTC back to 24p properly, because of post editing. Now, I
can't say for sure, whether or not the DVD's out there today are IVTC'able.
However, even if they are, there are areas (scenes) that are post processed
at 30p or 30i, and they are processed with the 24p footage.
At least I've seen this in the ST-NG dvd's. I have the "John Luke specials"
and they are this way (above) for sure.
Only shows that *ARE* IVTC capable are:
** Star Trek (original series)
** Star Trek Enterprise
Currently, I think they took ALL the Star Trek saga's off the air waves.
I haven't seen any since two years now. So you can't even capture them
now.
-vhelp 3936 -
Star Trek shows on SPIKE and G4TV
Most of what HBO and Showtime put on their HD channels is upscaled D1 or Digital Betacam 704x480. You would think they could find enough true HD material to fill one channel each. Seems a total rip to me.
really!! at what time ? (sorry, OT here)Star Trek shows on SPIKE and G4TV
-vhelp 3937 -
DS9, ENT, VOY, TOS and TNG all get airtime on local UPNs, SPIKE and G4TVOriginally Posted by vhelp
Here are the ones for this week:
Capture one of these and try to IVTC it. You'll see problems on special effects, as it was edited in tv-ready interlaced domain, it was not done in the film domain. They want it to look best on the primary viewing device at the time, interlaced SD TV sets.Code:• Star Trek - "Space Seed" G4, Sat May 06 08:00am CDT • Star Trek - "This Side of Paradise" G4, Sat May 06 09:30am CDT • Star Trek - "Devil in the Dark" G4, Sat May 06 11:00am CDT • Star Trek - "Errand of Mercy" G4, Sat May 06 12:00pm CDT • Star Trek - "The City on the Edge of Forever" G4, Sat May 06 01:00pm CDT • Star Trek - "Operation -- Annihilate!" G4, Sat May 06 02:00pm CDT • Star Trek - "Catspaw" G4, Sat May 13 08:00am CDT • Star Trek - "Metamorphosis" G4, Sat May 13 09:08am CDT • Star Trek - "Friday's Child" G4, Sat May 13 10:19am CDT • Star Trek - "Who Mourns for Adonais?" G4, Sat May 13 11:29am CDT • Star Trek - "Amok Time" G4, Sat May 13 12:39pm CDT • Star Trek - "The Doomsday Machine" G4, Sat May 13 01:50pm CDT • Star Trek: Enterprise - "Observer Effect" UPN, Sun May 07 03:00am CDT • Star Trek: Enterprise - "In a Mirror, Darkly" UPN, Mon May 08 12:00am CDT • Star Trek: Enterprise - "In a Mirror, Darkly" UPN, Sun May 14 03:00am CDT • Star Trek 2.0 - "The Menagerie" G4, Tue May 02 10:00pm CDT • Star Trek: The Next Generation - "Silicon Avatar" G4, Wed May 03 01:00am CDT • Star Trek: The Next Generation - "The Nth Degree" SPIKETV, Wed May 03 01:00pm CDT • Star Trek: The Next Generation - "Qpid" SPIKETV, Wed May 03 02:00pm CDT • Star Trek: The Next Generation - "The Drumhead" SPIKETV, Wed May 03 03:00pm CDT • Star Trek: The Next Generation - "The High Ground" G4, Wed May 03 07:00pm CDT • Star Trek: The Next Generation - "Deja Q" G4, Wed May 03 08:00pm CDT • Star Trek 2.0 - "Shore Leave" G4, Wed May 03 10:00pm CDT • Star Trek: The Next Generation - "Disaster" G4, Thu May 04 01:00am CDT • Star Trek: The Next Generation - "Half a Life" SPIKETV, Thu May 04 01:00pm CDT • Star Trek: The Next Generation - "The Host" SPIKETV, Thu May 04 02:00pm CDT • Star Trek: The Next Generation - "The Mind's Eye" SPIKETV, Thu May 04 03:00pm CDT • Star Trek: The Next Generation - "A Matter of Perspective" G4, Thu May 04 07:00pm CDT • Star Trek: The Next Generation - "Yesterday's Enterprise" G4, Thu May 04 08:00pm CDT • Star Trek 2.0 - "The Squire of Gothos" G4, Thu May 04 10:00pm CDT • Star Trek: The Next Generation - "The Game" G4, Fri May 05 01:00am CDT • Star Trek: The Next Generation - "In Theory" SPIKETV, Fri May 05 01:00pm CDT • Star Trek: The Next Generation - "Redemption" SPIKETV, Fri May 05 02:00pm CDT • Star Trek: The Next Generation - "Redemption" SPIKETV, Fri May 05 03:00pm CDT • Star Trek: The Next Generation - "The Offspring" G4, Fri May 05 07:00pm CDT • Star Trek: The Next Generation - "Sins of the Father" G4, Fri May 05 08:00pm CDT • Star Trek 2.0 - "Arena" G4, Fri May 05 10:00pm CDT • Star Trek: The Next Generation - "Unification" G4, Sat May 06 01:00am CDT • Star Trek 2.0 G4, Sat May 06 03:00pm CDT • Star Trek: The Next Generation - "Allegiance" G4, Sat May 06 07:00pm CDT • Star Trek: The Next Generation - "Captain's Holiday" G4, Sat May 06 08:00pm CDT • Star Trek: The Next Generation - "Tin Man" G4, Sun May 07 07:00pm CDT • Star Trek: The Next Generation - "Hollow Pursuits" G4, Sun May 07 08:00pm CDT • Star Trek: The Next Generation - "Darmok" SPIKETV, Mon May 08 01:00pm CDT • Star Trek: The Next Generation - "Ensign Ro" SPIKETV, Mon May 08 02:00pm CDT • Star Trek: The Next Generation - "Silicon Avatar" SPIKETV, Mon May 08 03:00pm CDT • Star Trek: The Next Generation - "The Most Toys" G4, Mon May 08 07:00pm CDT • Star Trek: The Next Generation - "Sarek" G4, Mon May 08 08:00pm CDT • Star Trek 2.0 - "The Alternative Factor" G4, Mon May 08 10:00pm CDT • Star Trek: The Next Generation - "Disaster" SPIKETV, Tue May 09 01:00pm CDT • Star Trek: The Next Generation - "The Game" SPIKETV, Tue May 09 02:00pm CDT • Star Trek: The Next Generation - "A Matter of Time" SPIKETV, Tue May 09 03:00pm CDT • Star Trek 2.0 - "Tomorrow Is Yesterday" G4, Tue May 09 10:00pm CDT • Star Trek: The Next Generation - "Unification" SPIKETV, Wed May 10 01:00pm CDT • Star Trek: The Next Generation - "Unification" SPIKETV, Wed May 10 02:00pm CDT • Star Trek: The Next Generation - "New Ground" SPIKETV, Wed May 10 03:00pm CDT • Star Trek 2.0 - "Return of the Archons" G4, Wed May 10 10:00pm CDT • Star Trek: The Next Generation - "Hero Worship" SPIKETV, Thu May 11 01:00pm CDT • Star Trek: The Next Generation - "Violations" SPIKETV, Thu May 11 02:00pm CDT • Star Trek: The Next Generation - "The Masterpiece Society" SPIKETV, Thu May 11 03:00pm CDT • Star Trek 2.0 - "A Taste of Armageddon" G4, Thu May 11 10:00pm CDT • Star Trek: The Next Generation - "Conundrum" SPIKETV, Fri May 12 01:00pm CDT • Star Trek: The Next Generation - "Power Play" SPIKETV, Fri May 12 02:00pm CDT • Star Trek: The Next Generation - "Ethics" SPIKETV, Fri May 12 03:00pm CDT • Star Trek 2.0 - "Space Seed" G4, Fri May 12 10:00pm CDT • Star Trek 2.0 G4, Sat May 13 03:00pm CDT • Star Trek: Deep Space Nine - "Armageddon Game" SPIKETV, Wed May 03 11:00am CDT • Star Trek: Deep Space Nine - "Whispers" SPIKETV, Wed May 03 12:00pm CDT • Star Trek: Deep Space Nine - "Paradise" SPIKETV, Thu May 04 11:00am CDT • Star Trek: Deep Space Nine - "Shadowplay" SPIKETV, Thu May 04 12:00pm CDT • Star Trek: Deep Space Nine - "Playing God" SPIKETV, Fri May 05 11:00am CDT • Star Trek: Deep Space Nine - "Profit and Loss" SPIKETV, Fri May 05 12:00pm CDT • Star Trek: Deep Space Nine - "Blood Oath" SPIKETV, Mon May 08 11:00am CDT • Star Trek: Deep Space Nine - "The Wire" SPIKETV, Mon May 08 12:00pm CDT • Star Trek: Deep Space Nine - "The Maquis" SPIKETV, Tue May 09 11:00am CDT • Star Trek: Deep Space Nine - "The Maquis" SPIKETV, Tue May 09 12:00pm CDT • Star Trek: Deep Space Nine - "Crossover" SPIKETV, Wed May 10 11:00am CDT • Star Trek: Deep Space Nine - "The Collaborator" SPIKETV, Wed May 10 12:00pm CDT • Star Trek: Deep Space Nine - "Tribunal" SPIKETV, Thu May 11 11:00am CDT • Star Trek: Deep Space Nine - "The Jem'Hadar" SPIKETV, Thu May 11 12:00pm CDT • Star Trek: Deep Space Nine - "The Search" SPIKETV, Fri May 12 11:00am CDT • Star Trek: Deep Space Nine - "The Search" SPIKETV, Fri May 12 12:00pm CDT
You'll end up with interlace errors (ghosting, jaggies) as well as chroma artifacts (again, due to interlacing).Want my help? Ask here! (not via PM!)
Yup, most everything prior to 2003 was edited in 4:2:2 480i/29.97 and 576i/25. HD was edited mostly 1080i/29.97 for series.
1080p/24 episodic editing was pioneered by Laser Pacific and is slowly going mainstream. -
I had the impression that studios were in the process of digitally archiving films, that are stored in their vaults? Kodak has/had an automated professional machine for years, that scans in each individual film frame at like 4K. This is way above HD resolution.
If only they would've made a master at 4K resolution, way back when the film was originally scanned in for DVD. Then they could just go back to that 4K digital master and scale it back down to HD 1920x1080. But it looks like the film industry were idiots, and only digitized all these films at 720x480/576.
btw...I have the first three seasons of Star Trek Next Generation. The video quality leaves little to be desired. Many scenes are compressed heavily, and it looks like they used a "grain disolver" technique to try to reduce grain. But it looks like it had a side effect. I see this "pattern" that is overlayed on top of the video. It's like a slight mesh effect. Not noticeable until you know what to look for, then it stands out all the time. I won't be buying any more. -
Movies are a separate issue from TV series. Movie effects were shot or rendered as progressive 24 fps. When movies are transferred to video, each frame is shot at video resolution with a tv camera (or flying spot scanner). The video can be output directly as telecined NTSC or PAL but that is old school. Most modern transfers (pre 4k digital cinema) are digitized frame by frame, filtered and color corrected and only then stored to video tape. The process had to be repeated with each new generation of videotape and separately for NTSC and PAL frame rates.Originally Posted by Wile_E
2" Quadruplex was replaced with 1" type C, then D2 (9 bit composite) or D1 (8/9/10bit 704x486/720x576 component), and then 1080i/720p HD formats.
4kx2K or 4kx4k Digital Cinema is a recent development. New films can be entirely digitally mastered (no film) or scanned from film. The master is digital data that can be converted to a couple of dozen distribution formats.
TV series were often shot on 24fps film but edited at TV resolution after transfer. D1 grade digital special effects were perfected during the 80's allowing advanced series like Star Trek Next Generation* and Max Headroom* to be edited real time in video. In all cases this was done with interlace Rec-601 YUV 4:2:2:4 and/or 4:4:4:4 video.
Twenty years later, this kind of workflow is becoming possible at HD and film resolution.
* These series and others edited at The Post Group in Hollywood.
http://www.postgroup.com/about.php
http://en.wikipedia.org/wiki/Max_Headroom
http://en.wikipedia.org/wiki/Star_Trek:_The_Next_Generation
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
16:9 shot, but 4:3 in DVD Architect.
By zovx in forum Authoring (DVD)Replies: 25Last Post: 14th Oct 2010, 09:46 -
automatic shot by shot video cutter
By monks19 in forum EditingReplies: 4Last Post: 26th Oct 2009, 20:17 -
What shot is this called?
By Chippy in forum Newbie / General discussionsReplies: 4Last Post: 18th Apr 2009, 00:47 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57
