I'm abandoning my vcr (it's currently in my office plugged into my Hauppuage PVR-150). I've been copying my home recorded videos successfully, but some rather old and no longer available videos show a form of copy protection that breaks up the picture. As these are treasured and only for my own use, does anyone know if I can defeat this with the PVR-150, or what I need in order to get an MPEG2 that I can put to DVD.
I've considered an H&B TX-100 as an alternative so would appreciate any feedback from anyone who's tried that too.
Regards, John
Time Base Corrector. Depends on what the interference type is. Is it really protection (Macrovision) or bad tape or unadjusted video head.
Defeating Macrovision...
http://www.circuitcity.com/ssm/Sima-GoDVD-Digital-Video-Duplicator-CT-200-/sem/rpsm/oi...oductDetail.do
you can try this or similar (50$) video copy amps form audio-video store, Radio Shack.... Google for video copy device... -
My Hauppauge PVR USB2 doesn't seem bothered by any of the MacroVision stuff I've sen to it. IIRC it uses the same encoder as the 150. Maybe there's a registry hack that can set it straight?
Capturing Videotape that has closed captions
By ian c-nall in forum Capturing and VCRReplies: 22Last Post: 4th Aug 2013, 23:33 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
Bitrate problem - PVR-150
By m0dts in forum LinuxReplies: 4Last Post: 14th Dec 2009, 14:47 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
capturing video from a vhs videotape player to PC
By kasfig in forum Capturing and VCRReplies: 7Last Post: 10th Mar 2008, 10:19
