    Jul 2003
    Singapore
    Any recommended program tat convert a avi file (Xvid, Ogg) to avi (Xvid, mp3) ?
    Apr 2004
    Miskatonic U
    Virtualdubmod to demux the ogg audio. An audio convertor to convert it to mp3, then virtualdubmod to mux it back again. Haven't needed to deal with ogg audio, so I can recommend a particular program. You should not have to change the video at all through this process, unless you have another reason to do so.
    Read my blog here.
    BeLight is usually ok for converting ogg to mp3
    Dec 2004
    Australia
    If it really is an avi then you might have problems demuxing it. ogg vorbis in avi is not a good idea. Could be that you have an ogm file though.
    Personally, I'd use mencoder since it can remux the video and convert the audio to mp3 in one go.
