I am interested to know which one is a better TV tuner card as the video chip in both the tuner cards are common. I am interested to have a tuner card which can give the best tv resolution on the monitor as well good recordings to make DVDs later. MSI 550 Pro-E is cheaper by $40 but is it worth it ?
vsenapati
they both use the same chipset. the only difference is ATI offers a 3 year warrenty. Also to note, the msi 550 pro-e is a pci-express card, so make sure you have the right slot before you get this one
I am using Intel D915 GAV mainboard which has two PCI express slots. I can always use MSI "Theater 550 Pro-E tuner card on my system. Is the performance of this board the same like that of ATI TV wonder Elite?
vsenapati -
yes, they are the exact same chipsets. so if the warrenty is no big deal go with the cheapest
Thank you for your advice. I will go for MSI Theater 550 Pro-E as it is $40 less than ATI
vsenapati
ATI Theatre Pro 550
By didikai in forum Capturing and VCRReplies: 2Last Post: 27th Feb 2012, 12:15 -
Hardware MPEG-2 Capture Software ATI Theater 550 Pro
By CaZeek in forum Capturing and VCRReplies: 9Last Post: 22nd Nov 2010, 12:57 -
Mainstream S/W to take full advantage of ATI 550 PRO H/W encoding
By inspiron2 in forum Capturing and VCRReplies: 2Last Post: 6th Jul 2008, 18:24 -
Video Capture with ATI TV Wonder Elite on Vista Ultimate
By Petes457 in forum Capturing and VCRReplies: 2Last Post: 30th May 2008, 10:55 -
Ati 550 pro best capture software...
By RE*S.T.A.R.S.*2 in forum Capturing and VCRReplies: 13Last Post: 14th Jun 2007, 18:46
