Hi,
Whenever I play an XVID video I get the msg thats says Windows Explorer encountered a problem and has to shut down. So then Win Explorer shuts down but the video does keep playing. Does anyone know how to fix this problem. I use Win XP.
thanks
regsvr32.exe /u shmedia.dll
That should fix it, since chances are it is caused by XP's buggy thumbnail shell extension.
If it doesn't help:
regsvr32.exe shmedia.dll
and you are back to normal. -
Thanks Celtic Druid....but I don't know what your telling me.
Could you give me instructions on what to do.
thanks -
W O W
That worked..you guys are da bomb...........Thank You ! ! ! ! ! ! !
Windows Explorer Keeps Opening Minimized in XP
By wulf109 in forum ComputerReplies: 6Last Post: 13th Sep 2013, 14:49 -
mkv properties in windows explorer (xp)
By Mokuton in forum Newbie / General discussionsReplies: 2Last Post: 24th Jul 2011, 12:24 -
Windows Media Player - problem with some videos with subtitle
By chico34 in forum Software PlayingReplies: 3Last Post: 25th Jul 2008, 14:57 -
Internet Explorer 6 problem on Windows 2000
By edong in forum ComputerReplies: 17Last Post: 23rd May 2008, 00:04 -
windows explorer in win2K
By fjmr in forum ComputerReplies: 10Last Post: 4th Oct 2007, 17:37
