    Jan 2006
    i have video encoder xpress and thought that it could encode compressed avi but i misread and misunderstood it. so now i'm wandering if there is any codec that could allow me to use what i have and convert my compressed avi --> dvd? Need help!
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Well, almost all AVI are compressed - like XviD or DivX. Just make sure you have the right codec to decompress the AVI - Use GSpot to find out which.
    /Mats
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I suspect if you have the correct codecs then any avi file can be read, but as I don't use it, I can't confirm this.
    If you want a cheap, easy to use convertor, look at VSO ConvertXtoDVD. It will take most types of input and produce a fully working DVD. As with all one-click-wonders, there is a trade-off between ease of use and final quality, but this one does better than most, and is much more reliable.
    If you want to produce the best possible output for your source, then you need to look at stand alone encoders and other tools.
    Read my blog here.
    Nov 2002
    It depends on what the **** do you mean by "compressed AVI". That's almost an oxymoron.
    From your topic "converting compressed avi w/ TsunamiMpeg Video Encoder Xpress" I'm guessing you have TmpgEnc XPress 3. But you aren't being clear what you want to encode to.
    You want to encode from AVI to MPEG2? AVI to AVI? Either way, Tmpg Xpress 3 will do it. For AVI to AVI you need to ensure you have the correct codec installed. G Spot or AVIcodec will tell you what codec is needed for your original AVI file.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...tells me OP wants to encode to mpeg2...
    /Mats
    Jan 2006
    thanks for all ur feedback. like i said...i am still new and confused but trying to learn. yes, i am trying to convert avi to mpeg2. the reason why i said compressed avi is cause tmpegenc says that it can only convert uncompressed avi, which is like video from dv camcorders. that is why i'm guessing that downloaded clips and videos from the web is compressed. thanks to all... i will try ur suggestions.
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Even DV AVI is compressed. I guess what's meant by "it can only convert uncompressed avi" is that without the corresponding codec, and using DirectShow, it can't handle anything besides uncompressed AVI.
    /Mats
