The last DVD that i made using SVCD2DVD worked out very well. I was very happy with the final result. My only slight bit of dissapointment that i had was with the menu. I loaded up a picture for the background image and in the preferences, menu settings i had the loop box ticked, which should play the mp3 audio track that i also used.
So when i load the DVD into the player, the menu comes up and the music starts playing for about 30 seconds then fades out. But then it doesn't play again like i wanted it to. I selected the loop option so what am i not doing right. What other boxes or preferences should i have checked or unchecked for the music in the menu to play continuously or loop, until i either select a Video or press the "Play All" button.
Thanks Michael in OZ.
Can you email me your menu files? (VIDEO_TS.IFO and VIDEO_TS.VOB). Also what build are you using?
Yeah sure Chris, the ones you want me to email you, i'm not really sure if they are these or not, but i emailed them to you.
VIDEO_TS 34KB Backup file of the IFO
VIDEO_TS 34KB DVD Movie Info
VIDEO_TS 1,240KB DVD Movie
These are the only 3 Video_TS files in the completed SVCD2DVD files.
The SVCD2DVD Version that i made the DVD disc on was the one before 2.1.2284, which was probably 2.1.2274. I have since downloaded the new 2.1.2294, but haven't used it yet.
Thanks for your help,
Michael in OZ. -
Chris, can you please give me an email address to send you the files.
Thanks. -
Well i recommend trying the latest build.
(email address is in my profile)SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks ChrissyBoy, i will try the latest version and see how that works.
trouble with SVCD2DVD menu selection highlighting
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 4th Sep 2011, 15:59 -
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 14:44 -
Really strange SVCD2DVD menu problem
By denali in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 4th Oct 2009, 12:41 -
Menu Question
By coloradoguy in forum Authoring (DVD)Replies: 5Last Post: 22nd Jan 2009, 02:04 -
Question re updating to latest version svcd2dvd
By Lord Flange in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 11th Oct 2007, 19:04
