I filmed some footage on my MiniDV camcorder, but upon getting the video out of the camera the audio level is too soft with too much soft background hiss.
While I can jack up the sound in editing, I need to clean it up as the background hiss also increases when I do that.
Is there an audio filter I can run the AVI through to deal with this issue?
What are my options here....freeware preferred of course...
Go to the following website which has some pointers on cleaning up audio:
http://www.digitalfaq.com/
Good Luck !!!
I think before I can use any of these I need to seperate the audio and video streams right? I think i can do that in VirtualDub....(????)
Like save the audio from the file as a WAV, then apply the filters to the wave, then bring the audio and video back together??
Is there any way to just work on the audio natively in the video? Audicity tried to load the entire DV file...with humorous results since it appeared to be looking for an MP3. -
try avidemux or if you have cyberlink powerdirector it has an audio cleaning tool.
Import/Capture Video from MiniDV - Audio is Choppy
By Guy Leatherman in forum Capturing and VCRReplies: 17Last Post: 21st Oct 2010, 12:35 -
Cleaning Up Audio
By Yeah in forum AudioReplies: 2Last Post: 10th Apr 2010, 00:41 -
cleaning up audio buzz?
By spiritgumm in forum AudioReplies: 1Last Post: 15th Apr 2008, 20:43 -
I need some help cleaning up Audio.
By efb91 in forum AudioReplies: 1Last Post: 22nd Sep 2007, 14:28 -
Video head cleaning & capture
By MTD in forum Newbie / General discussionsReplies: 8Last Post: 9th May 2007, 20:56
