    Mar 2005
    USA, Oklahoma
    My DVD burner is a Samsung TSSTcorp TS-H552B Firmware TS08. I used to burn DVDs on it regularly and never had a single problem. I got busy with other things and decided to take a break. I have now started to burn again but have come back to many problems. I am using the same batch of media that I was before. This drive is set as master and I have a CD burner set as slave.
    1. The burn times were horribly slow.
    I assumed this had something to do with the buffer levels that jumped erratically while burning. I changed my transfer mode to Ultra DMA 2 but had to uninstall and reinstall the drivers to get the change to stay. That seemed to solve the problem.
    2. Burning started to fail with a report of a "write error"
    After Googling, I checked with Nero InfoTool and saw that my System ASPI drivers were not configured or "didn't have a green bar." I downloaded Adaptec ASPI 4.72, and it reported my system ASPI drivers were just dandy. Confused and after some more reading, I just decided to kill them and reinstall the 4.6 versions from ForceASPI. Both programs now reported them working correctly. This solved that problem.
    3. Discs burned have a ton of errors towards the end of the disc.
    I tried to burn 4200mb files instead of 4464mb files and onto a different brand but still had as many errors. I changed the speed from 8x to 4x but while burning, I got a Write Error again..
    I ran out of media so now I am left wondering...anyone have any other ideas?? *sigh* And I'm sorry, but I dont have any of the logs...I didn't think to save them..*stupid moment*
    May 2002
    Germany
    I had a prob where I didnt have a dvd burner anymore, only cd!!! also certain functions. All this from one day to the next without reason.
    the fix: reinstalled the firmware and nero...dont ask me what the heck was going on though
    good luck
  3. I bought the same burnder, and have to exchange it three times, to get one that work at x4 speed. The symptom you have is typical of laser in the drive is having problem.
