  1. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    Hey yall, I'm havnig a problem converting flv to mpeg (either 1 or 2). I've tried both MediaCoder and Super. Here's the problem. The video converts fine but the Audio is way out of sync. Tried 2 different files 1 about 5 min and the other 22 min. Both get out of sync early in and drift off even worse. Is there a fix for this? Thanks
    Roger
    There are many ways to measure success. You just have to find your own yardstick.
    USA
    It could be VBR audio. It causes the same sort of problem with AVIs when run through an MPEG encoder. You might try a different audio setting in SUPER or the other programs. With a AVI the process is usually to save the audio out as a WAV and encode the audio separately from the video, then combine them back. I'm not sure how you would do that with a Flash file. But maybe SUPER has some settings that might work.
