I used DVD Slideshow GUI to create a DVD slide show. Everything is OK except that when this horizontal lines in the picture, these lines flicker. Anyway to fix this ?
Thanks in advance.
Try to export as .avs file open the saved file up a text editor and add this line as the last:
Save as .avs and render the new file with Quenc.Code:Blur(1.1,1.1)
This will add a blur to the slideshow - if it's not enough the higher the values. Let me know if it works for you and what values you end up with.
Tin2tin -
@tin2tin,
Thank you very much. It works.
Save to .avs file and cut & paste Blur(1.1,1.1) did the trick. All the flicker was gone for good.
DVD Slideshow GUI
By spike47 in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2012, 13:23 -
Help with DVD Slideshow GUI, please...
By MackoMaca in forum Newbie / General discussionsReplies: 3Last Post: 1st Oct 2010, 12:31 -
DVD slideshow GUI
By andwan0 in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2010, 08:51 -
DVD Slideshow GUI help
By snafubaby in forum Newbie / General discussionsReplies: 11Last Post: 9th Sep 2010, 16:15 -
DVD Slideshow GUI
By Tripodd in forum Authoring (DVD)Replies: 0Last Post: 27th Jul 2007, 15:19
