    Jan 2003
    Canada
    I demuxed a mpeg-2 file in order to apply 3:2 pulldown to the m2v stream. Instead of demuxing the mpg into a video stream and an audio stream, ffmpegX created 16 m2v files and 16 mp1 files. WTF? I should've ended up with a single m2v files and a single AC3 file.
    I then tried MPEG StreamClip and it correctly demuxed the mpg-2 file.
    What's going on here?
    Jan 2003
    Canada
    Okay, then I'll assume that ffmpegX's demux function is not working correctly. I'll use MPEG Streamclip for demuxing from now on.
  3. The documentation says: "This tool allows to demux mpeg-1 or mpeg-2 files into elementary .mpv and .mpa streams, or to demux VOB files into .m2v and .ac3 streams."
    Consequently, if the mpeg-2 file has a .mpv=m2v/m1v and .ac3 stream (instead of .mpa=m2a/mp2), it will not work. The tool used is mpgtx and it has such a limitation. However, it is planned to improve the demux tool so as it can also handle ac3.
