I have upgraded to the latest (2.1.2308) and half of the mpg files I have does add to the asset section. My avi files load fine. My files nor folders have any kind of weird characters in it. I have tried different file paths. The thing is, it works for some mpg files. Some of these files are new, some are old. I have ran out of ideas, what can I give you to see what's wrong. Thanks.
CAn you use the makesample tool (in the tools folder) to create a sample of a file that does this. (Make sure the sample also does it) and then email it to me?
Samsung PC Studio 3 and Windows unable to play mpg files
By gstewart in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2010, 21:06 -
PS3 Media Server-unable to add shared folders
By thegeeman in forum Newbie / General discussionsReplies: 4Last Post: 21st Feb 2010, 16:53 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 05:47 -
re: unable to add perm subtitle to mp4v
By sendero in forum SubtitleReplies: 0Last Post: 10th Aug 2007, 09:34 -
WMVHD files can't skip after half way...only on WMP
By aciras in forum Software PlayingReplies: 3Last Post: 5th Jul 2007, 10:31
