guys,
i have now for several days a problem with my encoded mpg2 files. whenever i try to encode the avi/xvid to a 720x480 ntsc mpg file i get these unsych files at the end. At the begining they look normal, but the longer the video is running the more unsych the video-sound gets. I never had something like this before... i used mainconcept mpg encoder, tmpg, CCE and with all the same result. I also tried different files, but all fucked up at the end. It simply doesn't make a sense- well... what does?
anyway, would be very glad if somebody has an idea
thx
Please watch the language.
What is the source ? (Video codec, resolution, framerate, Audio codec - g-spot or avicodec can tell you this)
What process are you using - directly loading the avi, frameserving frm avisynth or virtualdub etc ?
What guide, if any, are you following ?
At a guess, I would asy VBR mp3 audio is the cause, but you need to confirm this.Read my blog here.
here you go:
xvid, 640x272, 23,976FPS, AC3 (4 codecs installed: ACM, cyberlink, mainconcept, nero digital), 2 video codecs installed (xvid-mpg4 codec/decoder)
i don't follow any guide. I am used to set all settings as i need them:
ntsc 720x480, 29FPS, wide, 48.000khz... etc.
thx -
thx... i will try that, but i always encoded to 29 fps and it was never a problem.
If it is just standard AC3 then it should be solid.
Demux the audio track using virtualdubmod. Run it through AC3 fix to check it.
Encode your video seperately.
Bring the two together when you author. If you are still drifting out over time, rather than simply being out the whole length, then there is something else at play. If it is out the whole length, then you just have to adjust the delay to compensate.Read my blog here.
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
which freebie software for ripping the audio from AVI and MPG files ?
By soulbug in forum Video ConversionReplies: 6Last Post: 28th Feb 2011, 12:00 -
Audio and subtitles in mpg files...
By kdolan1973 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Aug 2010, 15:17 -
Change default audio in .VOB or .MPG files
By dsmith1984uk in forum AudioReplies: 1Last Post: 4th May 2010, 04:10 -
Export .mpg files in QuickTime Pro..no audio
By sknox in forum MacReplies: 4Last Post: 16th Dec 2007, 05:20
