I want to make a "montage" of scenes of a tv series I'm burning, but i need to know how to do that, I just want to be able to have a transition between them like fading into eachother, ect. I also want a song to play over it, and if it can be done, have audio from the show sometimes too, but if not then that's fine.
I am going to get dvdlab pro and I have the nero that came with my computer, plus power dvd.
by the way, what does clips mean in the dvdlab? what is it for?
thank you
Results 1 to 15 of 15
transitions,fadings and such are editing so you need an editing tool, like premiere elements, vegas movie studio, ulead videostudio.
(Real) freeware: Avisynth (but it is not a 'trivial' piece of software...)
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
If I got the Ulead® MediaStudio 6.5 Director's Cut would it be able to use the format video_ts that the dvdlab can use.
I don't want to have to convert it like you do for windows movie maker. -
what format do I save my clips in the unlead videostudio to be able to make them seen in dvdlab, like in vob format? please help me
I have one more question,
I converted a movie that I recorded on my dvd recorder and I used dvd shrink to put it on my computer, when I go into dvdlab my movie is in 5 vts files and they are only 30 minutes, how do i get them into 1 long movie file instead of only 30 minutes?
Or if that is the way to do it, then how do I get all 5 files to play like a normal movie would play, all together?
thanks -
someone please answer my question
How do i get my movie to be one file instead of 5 30 min chunks? i do not have chapters in my movie either.
"Song of the South" conversion
By dphirschler in forum Video ConversionReplies: 21Last Post: 3rd Oct 2011, 22:17 -
Does the psn outage make you hesistant about a "cloud" future?
By yoda313 in forum Off topicReplies: 11Last Post: 1st Jun 2011, 19:58 -
Gray "!" iTunes 8 annoying song location issue...
By Nintendo Fan in forum ComputerReplies: 12Last Post: 14th Jun 2009, 10:38 -
someone suggest screen capture software to make a "movie"
By graysky in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 05:08 -
"Taking the lyrics off a song"
By Salva Veritate in forum AudioReplies: 4Last Post: 13th Sep 2007, 19:05
