  1. When using 2.1.2308 it is the first time that the program stops with the following error message:
    Informationen über das Aufrufen von JIT-Debuggen
    finden Sie am Ende dieser Meldung, anstatt in diesem Dialogfeld.
    ************** Ausnametext **************
    System.Runtime.InteropServices.ExternalException: Der angeforderte Zwischenablagevorgang ist fehlgeschlagen.
    at System.Windows.Forms.Clipboard.SetDataObject(Objec t data, Boolean copy)
    at x3284ccece41ee22b.x529c233d07ffb0d5.x78aff39af5f14 8a1(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at DevComponents.DotNetBar.ButtonX.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Geladene Assemblys **************
    mscorlib
    Assembly-Version: 1.0.5000.0
    Win32-Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    SVCD2DVD
    Assembly-Version: 2.1.2308.33338
    Win32-Version: 2.1.2308.33338
    CodeBase: file:///C:/Programme/BadgerIT/SVCD2DVD%20v2/SVCD2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    Assembly-Version: 5.6.0.0
    Win32-Version: 5.6.1.9
    CodeBase: file:///C:/Programme/BadgerIT/SVCD2DVD%20v2/DevComponents.DotNetBar.DLL
    AxInterop.CodeLock
    Assembly-Version: 1.0.0.0
    Win32-Version: 1.0.0.0
    CodeBase: file:///C:/Programme/BadgerIT/SVCD2DVD%20v2/AxInterop.CodeLock.DLL
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    Accessibility
    Win32-Version: 1.1.4322.573
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    Interop.CodeLock
    CodeBase: file:///C:/Programme/BadgerIT/SVCD2DVD%20v2/Interop.CodeLock.DLL
    mscorlib.resources
    CodeBase: file:///c:/windows/assembly/gac/mscorlib.resources/1.0.5000.0_de_b77a5c561934e089/mscorlib.resources.dll
    System.Windows.Forms.resources
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms.resources/1.0.5000.0_de_b77a5c561934e089/system.windows.forms.resources.dll
    System.resources
    CodeBase: file:///c:/windows/assembly/gac/system.resources/1.0.5000.0_de_b77a5c561934e089/system.resources.dll
    Interop.QuartzTypeLib
    CodeBase: file:///C:/Programme/BadgerIT/SVCD2DVD%20v2/Interop.QuartzTypeLib.DLL
    System.Design.resources
    CodeBase: file:///c:/windows/assembly/gac/system.design.resources/1.0.5000.0_de_b03f5f7f11d50a3a/system.design.resources.dll
    Interop.DexterLib
    CodeBase: file:///C:/Programme/BadgerIT/SVCD2DVD%20v2/Interop.DexterLib.DLL
    System.Management
    CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
    Microsoft.VisualBasic
    Assembly-Version: 7.0.5000.0
    Win32-Version: 7.10.6001.4
    CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
    ************** JIT-Debuggen **************
    Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
    Konfigurationsdatei der Anwendung oder des Computers
    (machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
    Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
    Zum Beispiel:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
    Ausnahmen an den JIT-Debugger gesendet, der auf dem
    Computer registriert ist, und nicht von diesem Dialogfeld behandelt.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    When does this happen?
  3. Shortly after the title creator started.
    I was trying to make a DVD with two movies. The conversion from from mpg to S2D worked fine, but when the menu creator started the error message popped up and the program stopped.
  4. Okay, here some more details. Sorry for this long message.
    This error message appears, when the program stops working:
    Version: SVCD2DVD 2.1
    Build: 2.1.2308.33338
    Type: System.NullReferenceException
    Source: SVCD2DVD
    Message: Object reference not set to an instance of an object.
    InnerException:
    StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    Here is the corresponding log file:
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.1
    Executable: C:\Programme\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
    Executable size: 2,85 MB
    Executable size in bytes: 2998355
    Executable CreationTime: 27.04.2006 17:33:02
    Executable LastWriteTime: 30.04.2006 19:08:35
    Executable LastAccessTime: 01.05.2006 09:23:47
    ************************* Operating System *************************
    Operating System: Microsoft Windows XP Professional
    Service Pack: Service Pack 2
    Version : 5.1.2600
    Windows Directory : C:\WINDOWS
    OSLanguage: 1031
    CodeSet: 1252
    CountryCode: 49
    Local: 0407
    Total Physical Memory: 0,99 GB
    Free Physical Memory: 699 MB
    Total Virtual Memory: 1,99 GB
    Free Virtual Memory: 1,95 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: To Be Filled By O.E.M.
    Computer Model: To Be Filled By O.E.M.
    System Type: X86-based PC
    Computer Name: ADMINISTRATOR
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 2
    User Name: ADMINISTRATOR\PC
    ***************************** Processor ****************************
    Manufacturer: GenuineIntel
    Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz
    Description: x86 Family 15 Model 2 Stepping 9
    CPU Speed: 2,798GHz
    CPU FSB: 200MHz
    L2 Cache Size: 0 Byte
    CPU Speed: 2,798GHz
    CPU FSB: 200MHz
    11:25:21: Logical CPUs: 2
    ***************************** Time Zone ****************************
    Time Zone:
    ****************************** VIDEO *******************************
    Name: NVIDIA GeForce FX 5900XT
    Processor: GeForce FX 5900XT
    Mode: 1024 x 768 x 4294967296 Farben
    Video Ram: 128 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 32,4 GB
    DeviceID: D:
    FileSystem: NTFS
    FreeSpace: 1,50 GB
    ********************* END OF SYSTEM INFORMATION ********************
    11:25:21: SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    11:25:21: -->: DVDFolders creating VTS
    11:25:21: -->: VTS 01
    11:25:21:
    DVD Folders: Processing C:\Programme\BadgerIT\SVCD2DVD v2\dummymenuPAL.mpg...
    11:25:21:
    11:25:21:
    11:25:21:
    11:25:21:
    11:25:21: -->: VTS 02
    11:25:21:
    11:25:21:
    11:25:21:
    11:25:21:
    11:25:21:
    ---------------------------- ENCODING MENU ----------------------------
    TV Standard: PAL
    Image size: 768x576
    Resize size: 720x576
    11:25:22: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    11:25:22: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    11:25:22: libavutil version: 49.0.0
    11:25:22: libavcodec version: 51.4.0
    11:25:22: libavformat version: 50.2.1
    11:25:22: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
    11:25:22: Input #0, image2, from 'C:\Programme\BadgerIT\SVCD2DVD v2\menu\background%d.jpg':
    11:25:22: Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
    11:25:22: Stream #0.0, 25.00 fps(r): Video: mjpeg, yuvj420p, 720x576
    11:25:22: Output #0, rawvideo, to 'C:\Programme\BadgerIT\SVCD2DVD v2\menu\backgroundES.mpv':
    11:25:22: Stream #0.0, 25.00 fps(c): Video: mpeg2video, yuv420p, 720x576, q=2-31, 1000 kb/s
    11:25:22: Stream mapping:
    11:25:22: Stream #0.0 -> #0.0
    11:25:22: video:65kB audio:0kB global headers:0kB muxing overhead 0.000000%
    11:25:22: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
    11:25:22: INFO: [???] File C:\Programme\BadgerIT\SVCD2DVD v2\menu\backgroundES.mpv looks like an MPEG Video stream.
    11:25:22: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    11:25:22: INFO: [???] Found 0 audio streams and 1 video streams
    11:25:22: INFO: [???] Selecting dvdauthor DVD output profile
    11:25:22: INFO: [???] Multiplexing video program stream!
    11:25:22: INFO: [???] Scanning for header info: Video stream e0 (C:\Programme\BadgerIT\SVCD2DVD v2\menu\backgroundES.mpv)
    11:25:22: INFO: [???] VIDEO STREAM: e0
    11:25:22: INFO: [???] Frame width : 720
    11:25:22: INFO: [???] Frame height : 576
    11:25:22: INFO: [???] Aspect ratio : 1:1 pixels
    11:25:22: INFO: [???] Picture rate : 25.000 frames/sec
    11:25:22: INFO: [???] Bit rate : variable
    11:25:22: INFO: [???] Vbv buffer size : 34816 bytes
    11:25:22: INFO: [???] CSPF : 0
    11:25:22: INFO: [???] SYSTEMS/PROGRAM stream:
    11:25:22: INFO: [???] rough-guess multiplexed stream data rate : 0001248
    11:25:22: INFO: [???] target data-rate specified : 10080000
    11:25:22: INFO: [???] Setting specified specified data rate: 10080000
    Could you please send me a link to a previous build of SVCD2DVD, so I can at least work on my videos. Thx.
    B.t.w. In the latest build the trash can icon is hiding the scale of the media player. See attached image.
    Best regards,
    Meise
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you attach the log for the run in which the mpegs are processed and then you get the error?
  6. Hi Chrissy,
    pleasew find attached the log file
    could you please send me a link for the previous build. This worked fine for me.
    Thx,
    Meise
    svcd2dvdlog-20060501112758.txt
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok. You will have to email me for that.
