Hi,
I have some Xvid files with permanent subtitle.
1. How to remove the subtitles?
2. How to save the removed subtitle into *.idx/*.sub files to make it a switchable subtitle?
Thank you,
Jean
Results 1 to 10 of 10
If the subtitles are truly permanent and are part of the video and not in a separate file, there is no practical way to remove them except to cut out that part of the video, or mask it with a black bar.
You would be better off to find a version of the video without the permanent subtitle.
Try this filter in Virtualdub:
http://www.compression.ru/video/subtitles_removal/index_en.html -
Barnabas.
Thank you for your help.
I just played a little bit. The parameter setting is very important. The first try made everything blured. I'll try different parameters.
Thanks again,
Jean -
Jean,
I have never had an occasion to use the subtitle filter, but have used MSU's logo filter, and they both work a great deal alike. I would make sure that the filter area is set correctly, don't use the default option. It's a bit of trial an error to find the correct placement but should be worth it. -
alright, after finding out hot to use the filter i got another problem: first i select the file i want the subtitle to be removed, then i choose the filter and configure it. after that VirtualDub closes itselft everytime i do something like save it as AVI (F7) or press the "play" button.... what can i do???
How to add permanent subtitle to mkv
By ybe in forum SubtitleReplies: 0Last Post: 6th Aug 2010, 18:01 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
how do i make .srt subtitle files into permanent
By gangers in forum SubtitleReplies: 4Last Post: 28th Apr 2010, 17:41 -
How can I add permanent subtitle in TS file
By elmc in forum SubtitleReplies: 8Last Post: 19th Jul 2008, 03:32 -
permanent subtitle on a 720p mkv
By mahfuz in forum SubtitleReplies: 0Last Post: 3rd Oct 2007, 21:23
