I turned the parental control off and restart the machine but still can't see the movies!!
There's only sound. I tried several DVDs (some of them original and others I burned), they were all with picture except two DVDs!!
Any ideas?
Maybe you need to open it up and blow out the dust on and around the laser. I had to do that cause I just had the same issue with my sons ps2. Good luck..
Life is like a pothole, you just have to learn to get around it. -
I do that if none of my dvds is working.Originally Posted by dvdguy4
I burned 6 DVDs by the same program. Some of them are R rated. When I play them on a dvd player or on my PC, everything is fine, but with PS2 two burned DVDs have only sound NO picture!!Originally Posted by handyguy
I want to know.. why? -
What about the wire in the back of the ps2. Is it all the way in? Stupid question but cant hurt to check.
Thanx guys for trying to help.
I know dvdguy4.. sometimes a simple thing could be the problem.
But now I know what the problem is.
It's the dvd brand!! Yes.. because as I mentioned I burned many DVDs by the same program and with the same speed, but they are different brands. Sony and memorex are played without any problem, but Roco DVDs will play with sound only.
BTW.. they're all DVD+R.
I tried all of them in LG dvd player and everything was great!!
I hope you get some experience from this. Take care.
How to convert AVI to Xvid using VirtualDubMod that plays in DVDs?
By NeroLi8gerzid in forum Video ConversionReplies: 6Last Post: 2nd Sep 2011, 15:43 -
BetaMax plays fine for a while then bad picture
By LSchafroth in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2010, 21:31 -
Help! Audio on DVDs plays wierd. Incorrectly Mixed?
By rayden54 in forum Software PlayingReplies: 4Last Post: 18th Sep 2008, 23:57 -
PowerDVD plays DVDs with limited colors
By semmel in forum Software PlayingReplies: 3Last Post: 4th Jul 2008, 10:57 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 12:07
