Hi and thanks...
If you wanted to save a FCP project as something, in case you wanted to mess with it sometime in the future (forget about the assets them selves please)....and I want to delete all the render, scratch, capture, thumbnail, auto save, etc for that project....
What file should I export to?
.DV FILE...? Would that be the "HIGHEST COMMON DENOMINATOR'?
Is that better than a QuickTime .mov file?
What is the difference between a .mov file made from:
File, Export, QT Movie
And
File, Export Using QUICKTIME Compression, QuickTime Movie?
If the answer is exporting to DV is a good choice...is it supposed to take forever to render the audio if/when I pull it back in to FCP? Why do QT's come in so quick and .dvs take a long, long time...is that part of the cost of using the "highest quality"?
Bottom line: to archive projects/movies/ whatever (lets say 5 minutes of my kid playing soccer), and to keep it in a format other than a FCP project (cuz I need the space and want o delete stuff), what is the best export method, that allows me to grab that five minutes (oh say. a year from now) and make a "best of" DVD (or whatever) using that clip and (as an example) 20 others?
Boy I take along time to write simple questions...sorry...sometimes it takes me an hour and a half to watch 60 Minutes (joke, ha-ha)...anyway thanks for your patience...
Mark
In archiving, what I do is backup the "Capture" folder where
the media was inputed, either onto a DVD ( if it was all short clips),
or onto a FW HD ( if the whole project's media was more than say
2 hours). The files here are in DV/DVCPRO, wrapped in a
Quicktime Container, so they are your highest quality files.
FCP/FCE is based on Quicktime architecture, that is why Quicktime
files come in the fastest. Exporting the files out to the DV Stream
format changes the file to a DV Stream file, and FCP has to
re-render either the audio or the video, sometimes both, to
native Quicktime upon import to handle it.
( this is discussed in the FCP manual)
as for what is the difference between File -->Export--> QT movie
( which is a Quicktime reference file of your Sequence,
that contains all your edits up to this point), and File--> Export
using Quicktime Compression-->Quicktime Movie,
( which is asking FCP/FCE to generate a self contained Quicktime
movie, of your edits in the Sequence, using codecs you have
pre-selected in Quicktime to compress the sequence down
to your end result [MPEG-2, .mov, .mp4, etc.]), well that's
in the Manual also....
"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59 -
FCP exporting as QT Conversion ...
By macmithos in forum MacReplies: 3Last Post: 26th Sep 2008, 18:48 -
Codec choices for editing and exporting in Premier
By nhart1001 in forum Video ConversionReplies: 6Last Post: 8th Sep 2008, 19:01 -
exporting .m2v source files out of fcp without quality loss
By MacNiles in forum MacReplies: 9Last Post: 17th Aug 2007, 09:39 -
Exporting Video From FCP and iMovie...
By Mokat in forum MacReplies: 3Last Post: 29th Jun 2007, 19:52
