Results 1 to 11 of 11
    Nov 2003
    Cornwall
    I have an 8.4gb video downloaded from my minidv camcorder. I want to burn this to a dvd but when i run this through winavi or mainconcept the resulting video is only 1.5gb.
    Obviously this reduces quality, any ideas how to make the file output larger (4.5gb) so it can be burnt without such a drastic reduction ni quality.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    The AVI that comes from your camcorder is probably 25MBps DV-AVI w/ 1536kbps PCM WAV audio. I'm guessing your video is around 38 minutes long.
    Now even at the max compliant bitrate for DVD (10.08Mbps), this video would only take up around 2.8GB by my calculations. But you shouldn't need bitrates that high to keep similar quality levels - I'd suggest that WinAVI is crap and that you're using the wrong settings in MainConcept. 1.5GB is probably 5000kbps video and 224kbps audio which should produce a reasonable result provided your source is free of shake and noise.
    Are you noticing a visual reduction in qulaity, or are you just going by file sizes alone ?
    If in doubt, Google it.
    Nov 2003
    Cornwall
    Thanks for the prompt reply.
    the video is approx 44 mins long, can you advise me on the correct mainconcept settings.
    I was mainly looking at the file size but you can certainly see the reduction in quality.
    Apr 2004
    Miskatonic U
    The BitRate Calculator is your friend. You can find a selection of them here -> https://www.videohelp.com/tools?s=1#1
    The Videohelp Bitrate Calculator is nice and straight forward, but requires java. VideoCalc is a nice simple standalone calculator.
    Read my blog here.
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    File size does not really mean a lot without understanding the difference in codecs.
    A bitrate calculator should always be used. https://www.videohelp.com/calc.htm is as good as any.
    You should be able to get excellent quality using CBR 8000kbps for video and retaining the PCM WAV audio.
    Nov 2003
    Cornwall
    You guys are ace. I've just used videocalc and it shows a calculated bitrate of 9576 kbit/s.
    Where do i enter this in mainconcept.
    Apr 2004
    Miskatonic U
    RTFM, mate. All these programs come with extensive manuals and/or help files. Surely you can find your way now.
    Read my blog here.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Nov 2003
    Cornwall
    I realised the last post of mine was stupid as soon as i sent it. I knew where to set the constant bitrate.
    I think as it was 1am my brain must have been tired???
    An emotional day with my fav football team (Portsmouth) saving themselves from relegation.
    Once again thanks for all your help.
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Is cool. We all have brain fart days
    Read my blog here.
    Hmmmmphhhhhhhhhhh
    I get brain fart months....
