Not a question, but just an experience I thought I'd pass on. On shutdown, my computer hung and after a while I could hear a clunk, clunk sound of death emanating from my backup hard drive which is mounted in a mobile rack. Thereafter, on start-up the BIOS would not recognize the HD and XP would not boot. Removed the drive--everything OK. After trying repeatedly, I called Western Digital and they issued an RMA for replacement--obviously a bad drive.
Then realized, I'd forgotten to restore info from the backup drive since I did a re-format on my main video drive. Panic!!! Tried the freezer, a few knocks---nothing worked. Then tried on another computer--still dead. Thinking I didn't have the jumpers correct, I removed the HD from the mobile rack and installed directly. Everything was then OK. Relief--then copied all the files to the other PC.
For grins, I then re-installed the drive into the mobile rack--dead. Re-installed in another rack and everything worked again.
Bottom line--it was the mobile rack inner tray. I was truly surprised and relieved.
Just thought I'd share this experience since it seemed pretty unusual.
wwaag
Originally Posted by wwaag
oh my own..... experience along the same line as yours... I had a pc when boot up it gave a bad track zero error!!!! .... generally that means a dead hard drive.. but it turned out just a lose/dirty connector!! smile -
It's always a good idea to check connectors when you have a hard drive problem.
I've used mobile racks quite a bit with no problems so far. I would use models with included fans. Some hard drives run fairly hot and racks don't usually have good air circulation. The aluminum based trays help a little. Check those little fans occasionally also, they die fairly often.
The tray to IDE internal connector and cable can get damaged fairly easily as it is jammed up against the rear of the tray. That's what caused my problem. I have only had one with bent/damaged tray pins. The racks I use now have a handle/lever that unplugs and plugs the tray into the rack socket. It causes a lot less stress on the connectors. -
a harddrive here is some info...
http://techrepublic.com.com/5100-6255-5029761-2.html
http://www.tek-tips.com/viewthread.cfm?qid=398225
Also found this thread...
https://forum.videohelp.com/viewtopic.php?t=293910&highlight=disable+usb
Hard Drive Imminent Failure?
By AuroEdge in forum ComputerReplies: 9Last Post: 5th Dec 2010, 23:02 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
hard drive failure
By romanstopme in forum ComputerReplies: 3Last Post: 21st Sep 2009, 04:27 -
Hard drive failure/recover data
By bhbuckeye in forum ComputerReplies: 8Last Post: 12th Apr 2009, 21:50
