  1. can someone pls post how to do that ?
    If i have a 2cd Xvid rip of a movie, but i want to make it a single CD Xvid RIP, i dont mind compromising.
    Actually some movies do not deserve that much space :P but still nice enought to be stored.
    thx
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If in doubt, Google it.
    May 2006
    I have used AutoGK but for some conversions it took me almost 24 hours when normally it takes under 2 hours to get most movies down to 1cd. And the movies which took a long time to convert also ended up being encoded in a way the end picture was inverted/upside-down but besides that everything else was in a way I wanted. Any idea what I might have done wrong. Thanks
  4. can you give me Virtual Dub tut for this.....
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    https://www.videohelp.com/oldguides/avi2divx
  6. thanks for the reply. but can you please tell me how to make fixed size AVIs from virtual dub. like i have a file of say 1.45 GB in size and i want to compress it to 700MB.
  7. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I believe you have to use a bitrate calculator and manually adjust the bitrate.
    Google is your Friend
