Encoding started on Sat Apr 29 20:12:22 CEST 2006
MEncoder dev-CVS-060413-06:15-3.3 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
libdvdread: Couldn't find device name.
Reading disc structure, please wait...
There are 11 titles on this DVD.
There are 51 chapters in this DVD title.
There are 1 angles in this DVD title.
DVD successfully opened.
success: format: 0 data: 0x0 - 0xd4d67800
MPEG-PS file format detected.
VIDEO: MPEG2 720x576 (aspect 3) 25.000 fps 9800.0 kbps (1225.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400
Opening audio decoder: [liba52] AC3 decoding with liba52
Using AltiVec optimized IMDCT transform
AC3: 5.1 (3f+2r+lfe) 48000 Hz 384.0 kbit/s
Checking for AltiVec resampler : 0x0000000a, 2
Using AltiVec optimized resampler
AUDIO: 48000 Hz, 2 ch, s16be, 384.0 kbit/25.00% (ratio: 48000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=352]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES)
The selected video_out device is incompatible with this codec.
Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
Forcing output fourcc to 58564944 [XVID]
Audio LAVC, couldn't find encoder for codec mp3
IF i change audio codec to aac, it runs fine ?
If you need a mp3 codec try lamemp3. Works great.
I dont need one - got Divx 6 pro.... It is W version, going back to v works fine....
Is it the mpeg2enc ??? im not running intel, but G5 powerpc.
http://mjpeg.sourceforge.net/MacOS/mpeg2enc.intel
56 Transitions and 21 Effects missing in Mac version of PrCS4
By ValterMac in forum MacReplies: 2Last Post: 10th Jul 2009, 09:32 -
By ValterMac in forum EditingReplies: 1Last Post: 10th Jul 2009, 06:40 -
Please ignore: Can't encode -- Progress.app missing
By n7xy in forum ffmpegX general discussionReplies: 0Last Post: 13th Feb 2009, 09:43 -
mp3 organizer that can identify missing album tracks?
By ar7499 in forum AudioReplies: 4Last Post: 15th Dec 2008, 08:59 -
AutoGK missing subtitles when converting Asian version of DVD
By magicjohnson in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 18:38
