Hi,
I would like to do the following pls kindly advise if it is possible and if yes which software I need and is it easy or hard:
1) Transferring footage from mini tapes inside camcorder to pc
2) Transferring footage from mini tapes inside camcorder to VHS
3) Transferring from pc to VHS.....
For point 3 do I need specific software or equiment?
For point 2 do I need any specific software?
I understand if I can transfer the footage to pc I can just burn it using nero as dvd video? Is this true
How hard is it to do?
Do I connect the camcorder to pc, press play on the camcorder? If yes what software do I use to copy the footage onto the pc?
Once the footage is on the pc if I use virtual dub can I add jpegs to the beginning of the footage? Will this change the quality? Or will it be jumpy?
All help would be most appreciated
Thanks in advance...
Cheers!!!
Closed Thread
one topic is enough.
https://forum.videohelp.com/viewtopic.php?t=299535
VHS to File Conversion Newbie
By gk_terato in forum Capturing and VCRReplies: 5Last Post: 7th Jun 2011, 21:18 -
Conversion advice for a newbie
By darafat in forum Video ConversionReplies: 1Last Post: 20th May 2010, 01:17 -
Newbie conversion help
By chiller15 in forum Video ConversionReplies: 2Last Post: 7th Apr 2010, 07:41 -
Newbie problems: TS to Mpg conversion
By waehuun in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2008, 16:00 -
Very Newbie Conversion -- Vob to Avi
By dadada_999 in forum DVD RippingReplies: 3Last Post: 2nd Dec 2007, 12:51
