I have tried a few programs to make a backup of a specialty dvd d9 that I have. It has some data, some software, etc on it, it is not a movie. Any reommendations on which program will make an exact copy of a d9 to a d9. I have a DL burner with a dvd reader.
Any help would be greatly appreciated.
Results 1 to 10 of 10
If you are using xp , with nfts partition's you should beable to make an iso copy using nero .
On the other hand , if it's just plain data , then create a folder , and copy the dvd content here .
Use nero to burn the file's from this folder to dl media . -
Thanks for all of our replys.
I have tried them all and nothing works. Most look for VST files, but there are none since it is not a straight movie. TheDVD Decrypter in ISO read then ISO Write would not finalize. Every step worked except for finalizing the dvd. I let hit run for 8 hours and still not finalizing.
Any other suggestions?
Thanks -
Try somethinge else that can burn ISO to DVD to write the image created with DVDDecrypter - maybe ImgBurn?
/Mats -
You have to enable "Create MDS File" in ISO Read Mode Settings to record the layer break then load the MDS file (not the ISO file) into Decrypter before burning it.Originally Posted by kona777
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 10:14 -
exact copy with more than 2 folders ?
By takenotes in forum MacReplies: 3Last Post: 27th Oct 2010, 21:19 -
Record Now exact copy not playing right
By Knightmessenger in forum Authoring (DVD)Replies: 0Last Post: 2nd Mar 2009, 22:44 -
Exact copy of a DVD to a container playable in itunes
By jamsponge in forum DVD RippingReplies: 5Last Post: 20th Jan 2009, 11:19 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 18:32
