I have a bunch of pdf documents that I have to read through. But dear god, I find them hard to read off the screen in adobe. I find adobe has a "glossy" sort of look to it that makes it a bit "blurry." I dont have a printer sadly either, so I cant print it.
Essentially what I want to do is get a program that I can open a pdf file, copy it, and paste it into word so i can read it there.
Any ideas?
Thanks a bunch.
LG
if it is glossy - it is most likely a scan , and no mater what you look at it with - it is still going to look glossy because it is a picture
It is indeed a scan. I had no idea until I tried to convert them.
My boss is getting a sac beating on monday. -
Haven't tried it.. but maybe this:
http://www.techsmith.com/snagit.asp?CMP=KgoogleStm -
Depending on the resolution and quality of the scan you could try some OCR software to convert it to text data. May be more trouble than it's worth if you're just trying to read them though. Maybe just take them into a copyshop and print them out in B&W?
FB-DIMM are the real cause of global warming
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
adobe help!
By alintatoc in forum Off topicReplies: 4Last Post: 14th Apr 2008, 05:45 -
Adobe Encore Help
By Entengdigital in forum Authoring (DVD)Replies: 0Last Post: 17th Jan 2008, 03:36 -
The Shame of Adobe
By Cootah in forum SubtitleReplies: 0Last Post: 16th Jun 2007, 02:32
