I am trying to code RMVB to AVI,or actually anything that toast 7 will recognize and burn so I can play on a stand alone DVD player. I have gone through the other posts but they don't help me.
- I have macX 10.4.6
- Currently I am running ffmpeg 0.0.9u with installed binaries 20051201-2O
- My copy is registered
optional install--
- unable to use first link http://forms.helixcommunity.org/helix/builds/?category=helixdnaclient
so I downloaded the stable build from http://prdownloads.sourceforge.net/mplayerosx/reallib.zip?download
File copied into application support/ffmegx/ and renamed folder as "reallib"
When I drag and drop RMVB Source format shows the Video and audio which looks promising. I am unable touse "play" feature. I get a exc_bad_access (0x0001) KERN PROTECTION FAILURE and mplayer quits. Mplayer does play my other files fine
I have also renamed file RM, no luck. Encoding doesn't work, just processes for a few seconds and then "dings" finished.
I have also tried to convert RMVN file to DVD MPEG2ENC and then changed to "Decode with mplayer" and I get a SOURCE FILENAME ERROR- Please remove spaces and special characters from your source filename and folder names. (I read to do this in another post) The only space I can find is "Application support" so I changed that and I had to re-install all the binarys again so I am sure thats not it.
Anyway I am sure my problems lies somewhere in the beginning with the Reallibs install since it won't play.
I have been at this for quite awhile, weeks in fact and I hate asking for help.
ffmpegX is a awsome product. I think its the only thing that converts RMVB fles, if I am wrong please let me know. LOL
Thanks in advance for any help
Thanks for the reply.
I did some of this a few days ago so yes (didn't rename, my mistake) the file was already named reallib.
- I did copy the folder and not the zip file
- The folder contains 47 items
- I am sure its in the right directory, I am under the impression that the Video and audio in the source format would be blank if it was in the wrong directory.
Maybe I need the ffmpegXbinaries2006?
Thanks alot
-The other files that play with "play" feature are AVI files, I just tried a MPEG file and that doesn't work. I get what I used to get when I draged the RMVB file into source format-- Video=no video/Audio=No audio.
- If I only have the one RMVB file to use so I don't know if it is one file specific.
Thanks again for your help
RMVB to AVI problem
By cacovelloso in forum ffmpegX general discussionReplies: 6Last Post: 23rd May 2009, 08:53 -
How to convert AVI to .RMVB?
By whatever911 in forum Video ConversionReplies: 15Last Post: 29th Nov 2008, 10:29 -
rmvb -> avi again :evil:
By leovst in forum ffmpegX general discussionReplies: 2Last Post: 28th Mar 2008, 03:32 -
rmvb to mpeg/avi
By pcb in forum Video ConversionReplies: 3Last Post: 26th Jan 2008, 06:35 -
help with rmvb to avi?
By fruitpassion in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 17:46
