I wanted to add the real video option you refer to on the download page. However, when I went to the Helix page I could not find the macos-gcc3-pb file. It is refered to on the page but is not in the list of possible downloads. Looks like it has disappeared in the most recent update.
I have a version from ffmpegXr - will this still work?
Thanks.
Results 31 to 60 of 97
Simimilar thing with an mp4 file I had:Originally Posted by gmackenz
Encoding started on Sat Apr 29 16:09:46 CEST 2006
MEncoder dev-CVS-060413-06:15-3.3 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0xe8c411f
Quicktime/MOV file format detected.
VIDEO: [avc1] 640x480 24bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x31637661 size:640x480 fps:23.98 ftime:=0.0417
Opening audio decoder: [faad] AAC (MPEG2/4 Advanced Audio Coding)
AUDIO: 48000 Hz, 2 ch, s16be, 127.8 kbit/8.32% (ratio: 15975->192000)
Selected audio codec: [faad] afm: faad (FAAD AAC (MPEG-2/MPEG-4 Audio) decoder)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=480]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Forcing output fourcc to 58564944 [XVID]
Audio LAVC, couldn't find encoder for codec mp3
Exiting...
Just tried out the new version and problems I had with version "v" have got worse.
Scenario 1: Exported from iMovie (PAL) to a QT movie file at DV quality with stereo 44.1khz audio
Conveted with AVI DivX (mencoder) to avi. Video is fine but no sound
(Had this problem with version v and never found a way around it - tried different sound tracks etc.
Scenario 2. In version "v" I used this technique to get an avi with sound.
Exported from iMovie to DV and then used the same encoder to get an Avi. With the previous version this worked. Now I get a file that quick time does not understand (-2048).
(Edit: I reverted to version v and re-installed the old binaries and this DV file worked fine)
The log for version w was:
Encoding started on Sat Apr 29 15:46:56 BST 2006
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x1d86980
RAWDV file format detected.
VIDEO: [DVSD] 720x576 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:22 fourcc:0x44535644 size:720x576 fps:25.00 ftime:=0.0400
Opening audio decoder: [libdv] Raw DV Audio Decoder
AUDIO: 48000 Hz, 2 ch, s16be, 28800.0 kbit/1875.00% (ratio: 3600000->192000)
Selected audio codec: [libdv] afm: libdv (raw DV audio decoder (libdv))
Requested video codec family [qdv] (vfm=dshow) not available.
Enable it at compilation.
00, round: 1
Opening video filter: [scale w=640 h=352]
Selected video codec: [ffdv] vfm: ffmpeg (FFmpeg DV decoder)
Exiting...
Yes, real is the same as before, and it is also available here as written in the download pageOriginally Posted by whitedb
http://prdownloads.sourceforge.net/mplayerosx/reallib.zip?download
Does it work with this binary?Originally Posted by major
ftp.. [edit: now again hosted at sourceforge on the following link]
http://prdownloads.sourceforge.net/mplayerosx/ffmpegXbinaries20060307.zip?download
(the installer will complain it is a wrong version, for now just answer "cancel")
Major,
Thanks for looking at this. I installed the new binaries (no complaints from the installer) and tried my two test files.
Test 1: Quicktime movie exported from iMovie (PAL) at dv quality. Plays fine in QT but ffmemgX still produces an avi with no sound (same occured in version v). The log file is given below. I tried selecting different audio channels but still no audio.
Encoding started on Sat Apr 29 21:43:10 BST 2006
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x1efad08
MOV: selected audio stream (1) does not exists
ISO: File Type Major Brand: Original QuickTime
MOV track #0: 18 chunks, 0 samples
Audio bits: 16 chans: 2 rate: 44100
Audio extra header: len=24 fcc=0x6368616E
Fourcc: sowt
MOV track #1: 35 chunks, 0 samples
MOV: Found unsupported Field-Handling movie atom (10)!
MOV: Found unknown movie atom pasp (16)!
MOV: Found unknown movie atom clap (40)!
MOV: Found unknown movie atom colr (18)!
Image size: 720 x 576 (24 bpp)
Display size: 720 x 576
Fourcc: pcvd Codec: 'DV - PAL'
MOV: longest streams: A: #0 (18 samples) V: #1 (215 samples)
VIDEO: [dvcp] 720x576 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:7 fourcc:0x70637664 size:720x576 fps:25.00 ftime:=0.0400
Opening video filter: [scale w=720 h=576]
VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 1)
Movie-Aspect is undefined - no prescaling applied.
SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
videocodec: libavcodec (720x576 fourcc=58564944 [XVID])
Writing AVI header...
ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
Flushing video frames
Writing AVI index...
Fixing AVI header...
Video stream: 2430.351 kbit/s (303793 B/s) size: 2612627 bytes 8.600 secs 215 frames
Encoding completed on Sat Apr 29 21:43:28 BST 2006
Result with different audio channel selected
MOV: selected audio stream (3) does not exists
Test 2 Success: QT movie exported as .dv file. Now works with sound (back to how it was with version v)
Log file given below.
It would be great if you could fix the issue with it not picking up the sound from a QT movie.Encoding started on Sat Apr 29 21:43:53 BST 2006
AltiVec found
CPU: PowerPC
Building audio filter chain for 48000Hz/2ch/s16be -> 48000Hz/0ch/s8...
Building audio filter chain for 48000Hz/2ch/s16be -> 48000Hz/2ch/s16be...
VDec: vo config request - 720 x 576 (preferred colorspace: Planar 411P)
VDec: using Planar 411P as output csp (no 0)
SwScaler: FAST_BILINEAR scaler, from Planar 411P to Planar YV12 using AltiVec
Skipping frame!
Skipping frame!
Video stream: 2434.477 kbit/s (304309 B/s) size: 2592718 bytes 8.520 secs 215 frames
Audio stream: 128.000 kbit/s (16000 B/s) size: 144384 bytes 9.024 secs
Encoding completed on Sat Apr 29 21:44:21 BST 2006
Regards
Dave
The new binaries are now again at sourceforge, substituting the old ones.
A new version of ffmpegX (0.0.9w_r2) is now online replacing the old one, requiring the new binaries instead of the old ones.
Major, Installed 0.0.9w; downloaded unzipped and installed the 3 binaries(mplayer, mencoder, mpeg2enc. All installed, and I verified as correct. Everything appears to function normally with the exception that the main program does not recognize that mplayer and mencoder were installed, so I get the "install binaries" page every time I initalize ffmpegx. It does recognize that mpeg2enc binary is present.
Not much of an inconvenience, but thought you would like to know.
Thanks, Harley
(this is with r2 and newly-downloaded support binaries)
Trying to convert a Quicktime (.mov) file to .FLV.
Quicktime Pro says this about the video:
AAC, Mono, 16Khz, MPEG-4 Video, 160x120, Millions of Colors, 15fps, 235.99 kbps
Trying to convert the QT to DviX AVI (ffmpegx) gives me a single-frame video:Code:FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard Mac OSX universal build for ffmpegX Sun Apr 30 01:27:04 CDT 2006 libavutil version: 49.0.0 libavcodec version: 51.9.0 libavformat version: 50.4.0 Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 15.00 (15/1) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/mrbill/Desktop/WH-Dinner-Colber.mov': Duration: 00:15:32.1, start: 0.000000, bitrate: 238 kb/s Stream #0.0(eng): Audio: aac, 32000 Hz, stereo Stream #0.1(eng), 15.00 fps(r): Video: mpeg4, yuv420p, 160x120 Codec type mismatch for mapping #0.0 -> #0.0
Trying DivX (mencoder) *almost* works - I get video but no sound.Code:movtoy4m Copyright 2002-2006 Johan Lindström All rights reserved.. Sun Apr 30 01:29:31 CDT 2006 Input #0, yuv4mpegpipe, from 'pipe:': Duration: N/A, bitrate: N/A Stream #0.0: Video: rawvideo, yuv420p, 160x120, 0.01 fps Output #0, avi, to '/Users/mrbill/Desktop/WH-Dinner-Colber.mov.ff.avi.e.avi': Stream #0.0: Video: mpeg4, 160x120, 15.00 fps, q=2-9, 189 kb/s Stream mapping: Stream #0.0 -> #0.0 [mpeg4 @ 0x381324]removing common factors from framerate video:7kB audio:0kB global headers:0kB muxing overhead 39296.520174% bench: utime=33.815s FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard Mac OSX universal build for ffmpegX libavutil version: 49.0.0 libavcodec version: 51.9.0 libavformat version: 50.4.0 Seems that stream 1 comes from film source: 1000.00 (1000/1) -> 15.00 (15/1) Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/mrbill/Desktop/WH-Dinner-Colber.mov': Duration: 00:15:32.1, start: 0.000000, bitrate: 238 kb/s Stream #0.0(eng): Audio: aac, 32000 Hz, stereo Stream #0.1(eng), 15.00 fps(r): Video: mpeg4, yuv420p, 160x120 Codec type mismatch for mapping #0.1 -> #0.0
Code:Encoding started on Sun Apr 30 01:30:51 CDT 2006 MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team FIXME:Hardenabling SSE and SSE2 without detection Mac OSX static build for ffmpegX CPU: Intel (Family: 6, Stepping: 8) CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 success: format: 0 data: 0x0 - 0x1a8a980 ISO: File Type Major Brand: Original QuickTime Quicktime/MOV file format detected. MOV: selected audio stream (1) does not exists VIDEO: [mp4v] 160x120 24bpp 15.000 fps 0.0 kbps ( 0.0 kbyte/s) [V] filefmt:7 fourcc:0x7634706D size:160x120 fps:15.00 ftime:=0.0667 Opening video filter: [expand osd=1] Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1 Opening video filter: [scale w=160 h=120] ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4) ========================================================================== Forcing output fourcc to 58564944 [DIVX] VDec: vo config request - 160 x 120 (preferred colorspace: Planar YV12) VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.33:1 - prescaling to correct movie aspect. SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter videocodec: libavcodec (160x120 fourcc=58564944 [DIVX]) 1 duplicate frame(s)! Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Flushing video frames Writing index... Writing header... ODML: Aspect information not (yet?) available or unspecified, not writing vprp header. Video stream: 52.707 kbit/s (6588 B/s) size: 6141218 bytes 932.133 secs 13982 frames Encoding completed on Sun Apr 30 01:31:17 CDT 2006
I was excited to see a new version of ffmpegX. I hoped it would eliminate an error I got with the previous version. I get an Applescript error of "can't get text of item..." whenever I try to convert seemingly any kind of file to any other kind of file. There's no getting past this error. I really hope someone can help me. Apparently others don't get the error.
Look in the "About ffmpegX" window and check if you have 0.0.9w_r2. If not, download the application again.Originally Posted by harleycrobertson
The missing audio error seems to be gone with the new binaries, but the error we were discussing in this thread https://forum.videohelp.com/viewtopic.php?t=299024 is back with the new mencoder. The first version worked (without audio).
hi, major. i'm the guy who emailed you about this problem. what i said about the previous version is the same with the w version:Originally Posted by major
- the name of the volume is G4HD2 and the path is /Applications/ffmpegX.app
- the specific message is
Applescript Error
Can't get text item 2 of "/Users/das/Movies/lg.mov". (-1728)
(that filename and path is an example: the same thing happens with all files)
- i tried putting the file in the Applications directory too, but that didn't help
- i'm using Mac OS X 10.4.6, straight out of the American box. the international/localization settings are for United States and English
by the way, i _can_ use the ffmpeg that's in the ffmpegX.app package. for example,
./ffmpeg -i /Users/das/Movies/samplefq.dv /Users/das/Movies/samplefq.mpeg
I have seen older posts here reporting the same behavior, e.g.,Originally Posted by major
https://www.videohelp.com/forum/archive/t277315.html
Whenever I am trying to take a file and make it into an FLV i get this output:
Encoding started on Mon May 1 09:58:49 CDT 2006
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/LaCie Disk/A-Z CLIENTS/Morgan Stanley/bryan_edmunds':
Duration: 00:02:09.0, start: 0.000000, bitrate: 30313 kb/s
Stream #0.0(eng), 29.97 fps(r): Video: dvvideo, yuv411p, 720x480
Stream #0.1(eng): Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
Number of stream maps must match number of output streams
that is for taking a DV stream and trying I have also tryed with .mpg files and I get the same result, "Number of stream maps must match number of output streams" Any insight Major?
Thanks again for a wonderful Application!
It looks normal.. can you send me a file having this problem so as I can check? Use yousendit.com to send, to email major4@mac.com.
Major,
Tried wr3 with the latest binaries but still no sound from the .mov file from iMovie (the one I sent you)
Utumno, passthrough on mencoder has a known issue since years, that is, all audio is downsampled to stereo. This is a limitation of mencoder and I will report it to mencoder developers.
Apparently it can't recover the inversion in video/audio tracks. I was able to encode it with audio by opening the mov in QT Player, clicking apple-J, copying the audio track, deleting it and pasting it scaled back to video, so as the window saysOriginally Posted by whitedb
Video
Audio
Instead of
Audio
Video
Hope this helps,
ffmpegX 0.0.9y-L for Mac OSX 10.7 "Lion" released
By major in forum ffmpegX general discussionReplies: 10Last Post: 29th Jan 2012, 04:27 -
The most universal player out there?
By BettahDevil in forum DVD & Blu-ray PlayersReplies: 5Last Post: 24th Mar 2010, 21:09 -
Most universal format for PC's
By skinnyneo in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2010, 18:20 -
Thank you so much, Universal!
By Instant Martian in forum DVD RippingReplies: 5Last Post: 15th May 2009, 09:50 -
ffmpegX 0.0.9y released
By major in forum ffmpegX general discussionReplies: 12Last Post: 28th Nov 2008, 02:39
