if my laptop can use PC2100, or PC2700 will it hurt if i mix and match different speeds? I have an HP pavilion.
besides crucial, kingston, pny and micro. what are some other reliable makers of ram. i hear of hynix and k-byte
You have to install memory equal or better than the laptop need. This is just to take advantage on the higher speed memory can cost less when they are on sales.
Transcend is a good quality brand, thats ususually half the price or less of brands like Kingston.Originally Posted by rubberman
I put a Transcend 512MB stick into my Inspirion B120 for $34, a Kingston 512MB wouldv'e cost about $60.
Crucial.com is a good place to go to find out exactly what type of ram your laptop uses, but the ram they sell is WAAAY overpriced. For buying ram you should go to www.newegg.com -
I would use the same speed RAM of what you already have for stability reasons.Use CPUZ.EXE to find out what you have:
www.cpuid.com/cpuz.php -
If your Laptop use 2700 and you add 2100 stick laptop will lose some performance. Most of the time different brand same speed works ok,but don't be surprise if your laptop doesn't boot, or keeps rebooting, blue screen of death....
I updated an HP laptop few months ago ( ze 2000 I think) with 2 different brand of memory one is Kingman and the other is OEM brand. No issues so far.
http://www.newegg.com/Product/ProductList.asp?N=2000170381+1052907864&Submit=ENE&SubCategory=381
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 07:19 -
how to record video directly to usb port on laptop instead memory card...
By foler in forum Capturing and VCRReplies: 1Last Post: 9th Feb 2008, 04:00 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 15:31
