I "acquire" .avi files of tv shows that I miss when I'm at work. I imagine that these are "tivo" captures converted then uploaded. The vast majority of the time files I "acquire" of NBC, ABC, and, occasionally, Fox, and various cable networks playback fine, especially after I run them through VirtualDub MP3 Freeze. But, ones from CBS shiver then go to out of sync all the time. Is this something peculiar to CBS, and, their HD process? (I should've mentioned that all the broadcast netwrok shows are converted from HD broadcasts.) Or, what? I'm just curious, the present season is almost over, and, the answer won't make a difference again until fall.
Thanks.
I see a lot of people (relatively) have viewed this, but nobody, apparently, could answer my question. I still don't know if there is a difference between CBS HD formating, and, the other broadcast networks. But I began to notice that the dubs from the other networks were losing sync when I converted them, even when I used VirtualDub MP3 Freeze. So I "bit the bullet" got Goldwave, which somebody suggested when I originally asked about out of sync tv dubs. THe process is more involved, needing mores steps than if I just used VirtualDub MP3 Freeze, but through 5 dubs, so far, have not had the problem of losing sync.
ripped dvds when converted to avi out of sync
By angryassdrummer in forum Video ConversionReplies: 3Last Post: 9th Jan 2012, 06:43 -
AVI once converted has sync issues. Please Help!
By Marts1988 in forum Newbie / General discussionsReplies: 7Last Post: 5th Jan 2011, 01:45 -
Remux CBS HD flv file to MP4?
By txporter in forum Video ConversionReplies: 12Last Post: 24th Nov 2010, 19:18 -
Is it possible to fix a sync issue on a converted file (mp4)
By AndyD in forum AudioReplies: 3Last Post: 23rd May 2009, 21:28 -
alltoMKV converted MKV file sound out of sync.
By necrobutcher in forum Video ConversionReplies: 1Last Post: 10th Jun 2008, 17:25
