Anybody have any idea what could be causing this?
That screen only flashes(and beeps) this screen for a second or two...then the computer starts up as normal. Everything on the computer works perfectly...just this new "twist".
Not really too worried about it...it's been like this for two weeks or more...just curious. The computer is old and has(and still does) serve me faithfully.
Hi,Originally Posted by hech54
Generally beeps before windows starts is that there a indication that there was a hardware that the cmos post test had a issue with .... the exact meaning of the beeps, long and shorts, (there a beep code list) ... will depend on the who made your bios!! .... so find that out and then go to the manufature website and search for those beeps codes... and see what it says...
question does your cd rom work ok???
now from what i can see from your shot.... difficult to see, there appears to be a error with your cd!! but not sure since that part of the screen I couldn't read clearly! .... but if that correct.. then something with your cd drive.. it could be as simple as a poor or dirty connection... !! so that would be the first thing i do is reconnect things... that process cleans the connector and insures a good connection.... especially on old machines...
NOTE... I used to have a old 286.. where i would get a HD track ) error... smile.... generally a track o error is a DEAD HD.. but in that case.... it was just the jacks/plugs were dirty and the jacks needed to be replugged!! -
I removed the BenQ yesterday....same beep and it I think the LG now had the error....
Yea...the computer and drives work perfectly....used them all day yesterday.
I'll look for the CMOS info.
Utility for retiming subtitles
By uffish in forum Latest Video NewsReplies: 2Last Post: 23rd Feb 2011, 05:52 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 08:28 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 15:27 -
Anybody have DVXCEL Test Utility?
By codeseven in forum Capturing and VCRReplies: 0Last Post: 8th Apr 2008, 18:11
