I'm trying to convert an avi to DVD with 2-pass VBR but TMPGenc is shutting down midway thru (in middle of night) for some reason. I suspect that it's a space issue...my HD is only 9 gig - does 2-pass first create a 4.5 gig file, then, using that, create a second 4.5gig final file?
Thank you.
Jackie.
I would expect it creates a temp file while doing the processing, then when it is finished, it would write the file to the output folder. So yes, that is most likely the case.
Google is your Friend
AVI hard drive space
By josel in forum Newbie / General discussionsReplies: 7Last Post: 3rd Sep 2011, 13:24 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Home Movies Taking Huge Amounts of Hard Drive Space - Help!
By scormodo in forum Newbie / General discussionsReplies: 32Last Post: 11th Mar 2010, 15:38 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 17:55 -
Windows not recognizing all hard drive space after reinstall.
By GLE3 in forum ComputerReplies: 2Last Post: 12th Mar 2009, 09:42
