Heres the problem I have a few music videos / concerts I wanna encode and put onto an SVCD but Whenever I try to put some of the .avi and encode them with tmpegenc.. it says that they cant be opened and arent supported
I know one of them is Xvid its a dvd rip.. its a concert.. about an hour and a half concert but its 1.18 gb which in my experience.. dvd rip avis that are that length are usually more along the lines of 700mb ..
How can i figure out whats keeping me from opening the .avi in tmpeg
thanks in advance!
Sometimes not even the correct codec helps - in those circumstances, loading the AVI in VirtualDub, and frameserve to TMPGEnc, usually is the solution.
/Mats -
1. You'll get much better quality if you start with the original DVD and not your AVI backup.
2. https://www.videohelp.com/tmpgenc.htm#problems
Raise the priority of the DirectShow File Reader to the top and it should fix this issue.If in doubt, Google it.
vdub avi file opening problem
By naveenkrish in forum EditingReplies: 3Last Post: 8th Jun 2010, 12:54 -
TMPGenc crashes when opening avi
By Kromgol in forum Video ConversionReplies: 4Last Post: 19th Jul 2009, 10:03 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 12:07 -
Error message when opening AVI in Windows Media Player
By gomer in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 14:53 -
having trouble opening an avi clip from a Canon ELPH SD600
By Webster in forum Video ConversionReplies: 7Last Post: 12th Aug 2007, 19:06
