Hllo, As a relative newbie, I ask is there a program that can remove logos / comments etc from video files. These appear at random throughout the movie. Thanks in advance, Wayne (aka Walpoo)
Sort of.
VirtualDub has a logo filter available that can remove those. When they move around or are random throughout the file, it's much harder. And you may end up with a distracting blurred area where the logo used to be.
But give it a try. If it's MPEG format, VirtualDub Mod will work. Here's one guide:
https://forum.videohelp.com/viewtopic.php?p=1376335
You can find many more VD filters at: http://neuron2.net/ -
Basically - No, not without a trace. You could filter it thru VirtualDub using some delogo filter, but it takes a reencode, affecting the quality of the whole movie.
/Mats -
I find the blurred after affects of the removal just as annoying as the original logo. I wouldn't waste any time trying to remove it.
Google is your Friend
Removing Logos using DeLogo vdub filter
By Matt D in forum EditingReplies: 67Last Post: 6th Apr 2016, 11:26 -
bash scripts for extracting and removing subtitles from mkv files
By alidaf in forum SubtitleReplies: 0Last Post: 6th Aug 2010, 04:21 -
Removing waves or ripples from flash video converted to WMV files
By tymclemore in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2010, 17:20 -
Adding Transparent Logos onto VOB Files
By agtjones in forum EditingReplies: 27Last Post: 14th Dec 2008, 11:57 -
Removing Subtitles from VCDs and VCD-originated MPEG and WMV files....
By dadada_999 in forum SubtitleReplies: 1Last Post: 2nd Jan 2008, 20:49
