When I try to burn the mpeg file with VCDEasy tool it is giving an error telling that my drive cannot be recognised. Any one having the same issue ??
ERROR: No driver found for 'DVDRW IDE 16X' (Use "Force Driver" in the "CD Writer/Reader" settings page to set a driver manually)
ERROR: Cannot setup device 1,1,0.
Try a different driver. The default driver used is not always compartible with everything under the sun.
If you uncheck 'burn' it will create a cue/bin image that can be burned with something like nero.
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 05:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 21:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 21:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 09:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 16:13
