It only outputs 480i letterbox on S-Video but this is what I PVR record.Originally Posted by mikej3131
I dunno. Mute point. The 6412 won't output widescreen 480i anyway.Originally Posted by mikej3131
Odd but that is the way it is.
Seems odd ...
Results 31 to 41 of 41
Premium 4:3 sets offer similar features here. This is reaching lower end sets as well for example the Toshiba line. They concentrate 480 lines into the 16:9 vertical. For 16:9 PAL this would be 576 lines.Originally Posted by Kalos Geros
so you capture video from the motorola to the advc nd then to the dvd recorder?As for me, I mostly PVR cap the letterbox S-video with my ADVC-100 while outputting 1080i to the HDTV. The resultuing 480i DVD or computer playback is zoomed to fit the screen either in the Pioneer DVD player or using "expand 4:3" mode on my HDTV.
couldnt u just connect the rf cable to the dvd recorders rf input and recoprd that way with HD?Anways when I use the TV out on the HDTV I can record these channels in 16x9 WS on the DVD recorder! My TV has audio and video outputs and that is what I am using (tested with composite but there is also a S-Video output). -
You need the HDTV to tune into the HDTV channels. The tuner of a stand alone DVD recorder has no way of tuning in to the HDTV channels.Originally Posted by mikej3131
@edDV
My Pioneer DVD recorder does not have a FIREWIRE port but I know some DVD recorders do ... so ... can you hook the FIREWIRE out of the cable box to the FIREWIRE in on a DVD recorder to at least get the local HDTV channels in 16x9 WS ? ... for some reason I am guessing the answer is no LOL
I capture to computer hard disk as 480i letterbox and then view it off the computer or store it to DVDR(RW) using the computer's DVD writer. It would be possible to feed this over IEEE-1394 to an external DVD recorder at 1x transfer.Originally Posted by mikej3131
To be clear, I have a 6412 in the living room for general PVR recording and a 6200 (no HDD) in my computer room. I use the ADVC in the computer room for PVR. That and a AIW using MMC or a 550 + BeyondTV. -
No because the firewire out of the cable box (local channels only here) is MPeg2_ts at HD resolution. The 1080i/720p would need to be converted to 480i DV for the DVD recorder to work.Originally Posted by FulciLives
edDV, thanks for your earlier answer...
recording 16:9 anamorphic or HDTV 16:9 straight broadcasts to 480i letterbox physically reduces recorded vertical resolution compared to what could be achieved by capturing to anamorphic 480i and let the display correct this to the proper aspect ratio (zoomed picture on a CRt reveals scanlines while zoomed picture on LCD/Plasma introduces scaling problems and blurring...isn't it possible to record to 16:9 anamorphic SD from an HDTV broadcast??? sorry if I'm being a bit ignorant, we don't have HDTV available in my countryyet... -
You can only record what is output from the cable box. Expanded 480i letterbox should not show scan lines if the HDTV is any good.
Letterboxed 480i has 0.75x480 = 360 lines if displayed 4:3, but most HDTV models will vertically rescale for 16:9. You won't see scan lines. Vertical resolution will slightly blur but won't be seriously disproportionate to horizontal. (i.e. 720/1.78 = 405 vs 360).
Of course a 480i SD interlaced display (one that doesn't focus vertical scan lines for 16:9) may show scan lines but you indicated a LCD/Plasma progressive display.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
but can't you set the HD cable box to convert to anamorphic SD??? that seems to me like a big oversight...
So an HDTV CRT will physicaly still scan more than 360 lines when zoomed so scanlines won't be visible...that's better but the source is still "just" 360 lines...some time ago we laughed at PCs managing only that much and concluded how TV res was so much better and now we are regressing towards exactly that kind of experience... -
It is what it is. The Motorola 6xxx just ouputs downscale as letterbox in a 4:3 480i frame. No full height widescreen except at 720p or 1080i.
I'm not sure if the Scientific Atlanta 8xxx or other boxes do any different.
A PAL model would get 0.75 x 576 or 432 lines -
Well, that's close to the full anamorphic NTSC so I should be relieved... :POriginally Posted by edDV
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 17:14 -
How to produce a good Promotional Video...?
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2009, 15:38 -
Copy NTSC video tape onto a DVD-R (based inUK)
By nacnud23 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Nov 2008, 07:30 -
How do I handle both video and film-based material?
By CubDukat in forum DVB / IPTVReplies: 2Last Post: 20th Sep 2008, 21:12 -
Closed Captioning and jerky PC-based DVD video playback
By hollowman in forum Newbie / General discussionsReplies: 3Last Post: 21st Sep 2007, 10:17
