Hi![]()
I'm trying to convert an .mp4 to AVI.
TMPGenc won't open it, VirtualDubMod won't open it, Womble won't open it.
MPC will play it.
MPEG Streamclip will open it, but when I try to export to AVI I get an error: invalid frame rate.
I get the same error exporting to anything else.
If I open it in mp4ui and click on the video track and Export I get an error:
Exception: MPEG-4 internal
Reason: Couldn't read sample 1
What's going on ??![]()
Thanks![]()
Results 1 to 9 of 9
What Baldrick said. And a MP4 is already a type of AVI. MP4 is just the name of the container, it doesn't really tell you anything about the format within. Drop it into Gspot (V2.52) and it should tell you the audio and video format it is.
Then SUPER or DivxToDVD or other programs may be able to convert the file to the format you want. -
Most dont get the idea of what is :
Mpeg4
Mp4
To convert mp4's try Mp4Cam2AVI , work's like a charm on all my nero mp4 converted dvd's . -
Oh yes Mp4Cam2AVI would work well with nero digital files. But sometimes when i try this with other mp4 which I don't know what are within it results in an avi file that doesnot play. Dropping this avi file into VirtualDubMOd and the mod says something about H264. The output avi file is useless anyway for this case.
celtic_druid said:
mp4 is not a type of avi.I found this page about container formats that makes it a lttle more clear, at least to me:
http://en.wikipedia.org/wiki/Comparison_of_container_formats -
Wouldn't it be nice if an .mp4 was one type of file, and an .avi another, and if you're software could play one .avi it could play every other one, and it wouldn't matter what codec you used to create it ....
Convert MP4 to AVI?
By JS12 in forum EditingReplies: 0Last Post: 22nd Jan 2011, 08:58 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
[How do I] Convert MP4 to AVI
By supe2 in forum Video ConversionReplies: 1Last Post: 14th Dec 2010, 06:47 -
Best software to convert VOB to mp4 or AVI, or AVI to MP4?
By 80zforever in forum DVD RippingReplies: 7Last Post: 18th May 2010, 12:32 -
how to convert FROM MP4 to avi etc.?
By neutrino78x in forum Newbie / General discussionsReplies: 2Last Post: 26th Jun 2007, 05:09
