    Feb 2006
    hey how do i convert a .WMV to .MOV?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    There is no straight forward way that I am aware of. You would most likely have to convert to a different format first, such as wmv to mpg, then mpg to mov.
    Google is your Friend
  3. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    The latest version ($30?) of QuickTime Pro will convert WMV to MOV ... assuming that the source WMV file isn't DRM-protected.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    If I remember correctly, ffmpeg should be able to convert WMV to MOV (again, assuming it's not DRM-protected, and I'm not sure about ffmpeg's support for WMV3/9... I'd have to check). I'm not sure whether or not mencoder can do it as well, but it probably can (under similar conditions).
    SUPER may also do it (since it uses ffmpeg and mencoder as well).
    Feb 2006
    I got a copy of river past video cleaner from a freind, and I installed quicktime but for some reason when i to the video output .mov wont show up
    http://www.riverpast.com/en/support/tutorials/convert/wmv/mov.php
