Results 1 to 9 of 9
    Jul 2003
    I have a LiteOn LVD-2001 with an updated bios.
    Well it was working ok for last year but now I get
    iso disk on the display when I turn it on.
    then wait
    the some other stuff some times I hit play and it
    says play in the display but never does.
    turn it on and off 1 2 or 3 times and it works.
    plays fine after this...menus and everything are fine
    IS this a junker?
    thanks big time for help with this unit has NOT seen much service and I was
    surprised when all this started to happen.
    If I need to junk this thing is there an under $100 player
    I can pick up at bestbuy walmart or something like it and
    get good player with good features?
    maybe even play back wma video files...although I am not
    sure how to burn them to cd/dvd and get a menu for multi.
    Etrin
  2. Banned
    Feb 2005
    USA
    Most players today are under $100. Even some recorders are in this price range. My last player purchase cost me nothing as it was free with the purchase of other equipment. It works better and has lasted longer than my first Sony player.
  3. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    Have you tried something like this:
    http://www.amazon.com/gp/product/B00008EM7U/
    Cheaper than buying a new player.
  4. Try opening it and cleaning the laser and spindle with a q-tip wet with alcohol. I've had it work many times.
    Jul 2003
    will give it a good scrubing tonight and thanks for the help
    etrin
    Jul 2003
    Ok I must have screwed up something.
    I took the top of the drive and gently cleaned the lens.
    Put the top back on and power up.
    plz wait in display
    I hit open and it did. put in a disk and hit close it closed.
    Spun up and nothing.
    display says plz wait.
    I hit open,,,,display blinks open then goes to close in the display
    even though the drive is closed and won't open.
    can someone tell me what I screwed up and maybe a fix?
    thank you for any and all help
    etrin
  7. The tops sometimes have slots in them that slide into a plastic part on the faceplate, you may have missed and got the top on wrong. Take the top back off, if it works OK with the top off, you got it back on wrong or bent it in the process.
  8. Are you looking for another Divx/DVD player or just a regular DVD player?
    Jul 2003
    Well I tried about everything. Now it will open and close..you put in a disk..
    it says dvd...please wait...then ntsc message....then a lot of wurring and clicking
    if you eject the disk and hit close ...then play it says no disk.
    But it won't play.
    I must have done something to piss it off LOL
    jagabo it looks like I am looking for an inexpensive dvd and or dvd/divx that
    will play dvd-r and dvd+r.
    etrin
