I have been using TMPGEnc DVD Author for years. I had to format my PC about a week ago and after i installed TMPGEnc DVD Author again, for some reason, all of the VTS files that I make using the program, doesn't have any sound. The MPEG-2 file that I want to create the VTS files has sound, so why doesn't the VTS files made from the MPEG file have sound?
That's a plugin for TDA that requires a separate licence (i.e., purchase) from TDA. The ac3 plugin requires periodic on-line activation (reactivation) to keep working. If the audio of the clip you're trying to edit in TDA is ac3 you will not be able to hear it unless you have the plug-in. Also, the plugin gives you the option to encode PCM audio to ac3 when authoring. You can purchase a license for the plugin from PEGASYS.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 16:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 14:37
