  1. OK I can capture with the PV-231 in VCD format, great, Nero will do it's thing without error, I can watch it OK...Now if I cut the original with anything, NERO will not read it as a valid VCD format. Question is why? I have tried to use Ifilm Edit, TPMEGnc, makes no difference. The settings are for VCD in all the edit programs. So how can I cut a large file and burn with Nero. Many thanks in advance.
    Bud
    Apr 2001
    Puerto Rico, USA
    Use CinePlayer Editor (formerly Ifilm Edit). Just be sure to activate the VideoCD option in the Preferences/VideoCD Options menu. Nero will accept and burn it.
    Good Luck!
  3. Many thanks...I did a copy of Iflim and it works great. No more problems with NERO.
    Bud
    Apr 2001
    Puerto Rico, USA
    Glad to help, Bud!
