    Apr 2006
    Hi...My first post here...hope someone can help.
    When I copy any 'series' programmes with a number of episodes from the tv to a dvd disc I find it very difficult to find the beginning of each episode on the dvd without having to fast forward through the disc. Is there any way that a MENU can be created on the disc to identify each episode so that you can go straight to it without having to trawl all the way through the recorded disc?
    Tanks for any advice...........
    Feb 2004
    Australia
    dvdauthorgui will help you with menu's .
    The gimp to design jpg's for static menu's , or png's with alpha's for motion menu's .
    Pgcedit to edit nav command's should you need to adjust nav command's of menu's .
    Koolplaya - capable of playing dvd material from either dvd or for project folder .
    Strip each title into seperate video and audio stream's .
    Convert audio to ac3 .
    Add each m2v/ac3 as individual title's in dvdauthorgui .
    Add menu , button's , basic navigational command's .
    Author to folder .
    Play test .
    If menu error , correct by loading project into pgcedit , and re-edit navigational command's .
    For help , check out my guide's , there's plent of pgcedit usage to guide you .
    When all is fine , you can proceed to burn project , and enjoy .
