i use dvdx to convert dvd to divx avi.
i want to view these divx avi files on my tv so i'm
looking for a FREE program to put .avi files onto DVD/CD
without altering the size of the file.
e.g. i have a movie converted to divx, it is 700mb big and i want to put it on vcd to
watch on my dvd player.
thanks for any help in advance!
Results 1 to 12 of 12
Best option is to get a DivX capable player. Then it's just a matter of burning the AVI as data to CD or DVD.
If that's not an option, conversion of avi to some other format (mpg1 or 2) is necessary, and as avi file size has nothing to do with the file size when converted to other format, you'll get different file size depending on target format.
Generally speaking VCD is smallest, SVCD in between, and DVD biggest.
VCD is 10 MB/ minute, SVCD 15-20, DVD anything between VCD and 80 MB/minute, mostly in the area of 40 MB/minute when going AVI -> DVD.
/Mats -
All the answers are right, here.
If you have the DVD already, why bother converting to DivX? Just back it up to DVD.
Not that we're supposed to discuss this topic but if these are files that you've downloaded from the internet, then you're best option is to buy a $60 Philips DVP642 DivX player and burn your movies as data to either a 700MB CD or put as many as you can fit on a data DVD. -
If you have an Asda store nearby (not many of them in Ireland) drop in and get the Dual dvd860 ... it plays divx/xvid and mpeg 4 from cd or dvd as well as vcd/svcd ... also supports mp3 photo cd jpeg etc DD5.1.. DTS and has 2 memory card slots (reads mmc, sd, memory stick etc and others) and can read divx/xvid mpeg4 jpegs etc direct from the memory card ... it also has optical and coaxial outputs to connect it to your surround amplifier (also has analogue connections) ... not had a disc that it won't play ...(although i haven't tried cheap nasty media (princo etc)) ... and the best thing is ... it only costs £39.47 .... a good buy in my opinion
Of course, there is always trade-off between space and quality.Originally Posted by guns1inger
he(?) has made the movie 700mb so the quality in divx isnt going to be great so the switch to vcd wont hurt too much in quality.
IMHO vcd can be reasonable quality if going for higher bitrates, 1850 and using two pass encoding fron a good clean sauce.
divx player saves the pain and aggro of re-conversion
Well, "VCD" @ 1850 is not a VCD, neither is a 2 pass (hence VBR) encode VCD compliant. VCD is CBR 1150 kbps tops - that's it.
/Mats
Auto DVD Rip - Put the disc in the tray and the program does the rest
By dw-wizard in forum DVD RippingReplies: 8Last Post: 17th Feb 2012, 00:54 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
A program to put wavefiles on a DVD
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 27th Apr 2009, 01:47 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 02:19 -
How many Divx movies should I put on one DVD+R?
By Hank Kinsley in forum Newbie / General discussionsReplies: 11Last Post: 17th Aug 2007, 04:39
