  1. I'm looking to set the values of an Array outside of a procedure in excel but I'm not sure it can be done. This is what I have so far -
    Public Names(1 To 5) As String
    Set Names = Array("name1", name2", "name3", "name4", "name5")
    but the "Set Names" argument gives me an "Invalid Outside Of Procedure" error.
    Can this be done ?
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  2. Member pchan's Avatar
    Mar 2003
    Singapore
    Try this ...
    Just remove "Set". But remember... the index starts from zero.
    Names(0) = "name1"
    Names(1) = "name2"
  3. Member pchan's Avatar
    Mar 2003
    Singapore
    Sorry.. I did a test and it bomb.
    This will work.... change String to Variant !
    Dim Names As Variant
    Names = Array("name1", "name2", "name3", "name4", "name5")
    Funny thing... declare Names(1 to 5) as String still work but have to assign individually. In this case, the index starts from 1. Whereas for Variant, the index starts from zero.
  4. Originally Posted by pchan
    Yes, I've come to those conclusions too ! It's a weird one - thanks for your help.
  5. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    @VCDHunter - I know you're sorted, but for pchan's benefit...
    You cannot assign to a static array, only a dynamic one, such as Dim Names() as String. Then if you need a specific size, you can Redim Preserve.
    You can also create non-zero index arrays, but the zero index array is standard.
  6. Member pchan's Avatar
    Mar 2003
    Singapore
    @tekkieman, Thanks. Is this you are refering static vs dynamic...
    Sub test()
    'I think you refer to this as STATIC ARRAY !
    Dim Names(1 To 5) As String
    Names(1) = "name1"
    Names(2) = "name2"
    Names(3) = "name3"
    Names(4) = "name4"
    Names(5) = "name5"
    'Test dump...
    Sheets("Sheet1").Range("A1").Offset(0, 0) = Names(1)
    Sheets("Sheet1").Range("A1").Offset(1, 0) = Names(2)
    Sheets("Sheet1").Range("A1").Offset(2, 0) = Names(3)
    Sheets("Sheet1").Range("A1").Offset(3, 0) = Names(4)
    Sheets("Sheet1").Range("A1").Offset(4, 0) = Names(5)
    End Sub
    Sub test2()
    'I think you refer to this as DYNAMIC ARRAY !
    'Test dump...
    Sheets("Sheet1").Range("A1").Offset(0, 0) = Names(0)
    Sheets("Sheet1").Range("A1").Offset(1, 0) = Names(1)
    Sheets("Sheet1").Range("A1").Offset(2, 0) = Names(2)
    Sheets("Sheet1").Range("A1").Offset(3, 0) = Names(3)
    Sheets("Sheet1").Range("A1").Offset(4, 0) = Names(4)
    End Sub
