If having a DC, I’m sure that you’ll shoot bundles of photos. And these photos will sooner or later take up much space of your hard disk. This problem troubles me a lot, have you ever met the same problem? If you do, please follow my steps to create a photo slideshow and burn DVD/SVCD/VCD for storing forever.
BTW. The software I use is, which gets a 4-star rating both of CNET editor and users in Download.com
1. Start up. Click “New” and choose the “New Photo Slideshow” to add your photos. You can add one by one or simply use “Add all”. Choose YES to add more from other folders and NO to finish adding.
2. Edit. Editing tools like Rotate, Flip, Brightness, Blur, Contrast, Mosaic and Filter, are included. You can also click Decorate to add texts and clips for each photo. The slideshow looks better if being optimized beforehand.
3. Motion and Transition effects. Select you fond one and apply to the photo. But I suggest to click the Random Effect to all button, then make a little modification. It saves lots of time, especially when too many photos staying on the story line.
4. Music and narration. Whether to add music and narration to single photo or background music depends on you. If you do, you can make a clip of the music or narration through setting a Begin Time and an End Time, trim the volume and make a Fade in and Fade out effect to your music or narration.
5. Create template menu. Choose one from the template list. The text and frame can be modification if you need.
6. Share your story to a DVD. Choose Burn to disc, Create disc image, Create MPEG file and Create DVD file. After finishing the setting, click the Start. Then you’ll get your wonderful DVD slideshow.
Notes:
It only stands for my opinion, if you want to know more detail, please visit the offical website.
:P
You are in breach of the forum rules and are being issued with a formal warning. SPAM!
/ Moderator Baldrick
Closed Thread
i´ll recomend you DVD slideshow GUI
https://www.videohelp.com/tools?tool=DVD_slideshow_GUI
it´s free and easy to use
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
Build DVD Structure without Menus and Create them Separately
By Bruno AUgusto in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2011, 13:50 -
Encore CS4 DVD Image Build is incredibly slow
By aple in forum Authoring (DVD)Replies: 1Last Post: 22nd Jul 2011, 11:42 -
Why is Imgburn DVD Function buried under Mode>Build?
By jimdagys in forum Newbie / General discussionsReplies: 27Last Post: 1st Dec 2008, 19:48 -
Whats the cheapest way to build my dvd collection?
By ryangarfield in forum Off topicReplies: 15Last Post: 12th Jan 2008, 18:20
