I have discovered that AviSub 1.6 will do the job.
Input your AVI and your subs (IDX and SUB), and the AviSub program will generate a *.divx file that will play just fine on the Philips 642.
Now there is no need to do all that tedious conversion to SRT using SubRip. By using the "divx" container, you get to keep high quality bitmap subs that look as good as DVD subs!
The Cons:
1. They say your AVI can't use MPEG quantization matrices.
2. There aren't many tools out there that let you work with the divx container, so options for editing and fixing audio synch may be limited.
3. AFAIK, the IDX and SUB are converted to xsubs, another form of bitmap subtitles, so it probably won't be possible to recover the original vobsubs from the divx file...it's probably best to make sure to keep your original IDX and SUB in case you need them later.
Anyway, I haven't done much testing on the 642 yet, but I'm hoping others will chime in with their experiences using the divx container on the 642.
When I watch the successfully generated divx container files on a Philips DVP642/37 - firmware 0112, I'm seeing random and sporadic dropouts of the xsubs; occasionally some bitmaps disappear too quickly, and other subs are skipped completely. If I rewind and watch the scene again, different subs are affected. This happens whether I used VobSubs or .srt text subs.
If you have any subs that are on three lines, the third line won't be generated by AviSub and so it won't appear.
If you load VobSubs there's no way to select mapping for either WIDE or LB if both ID's are present; the offset controls in AviSub are disabled and the subs are placed in the black bar area of a letterboxed widescreen video; this is the wrong place for viewing on widescreen TV's. Hypothetically the .idx file could be edited by hand to force a different placement. -
Every single divx certified player will behave in the same way as the 642, wether its philips or samsung or toshiba, thats what certification ensures.Originally Posted by LisaB
to modify the subtitle position the best tool i found so far was srt2bmp it willl let me tweak the position of srt subs(idx was not supported altough new beta version does)
Xsub creation tools
srt2bmp guide
avisub
divxmuxGui
Sub2divxI love it when a plan comes together! -
Have used AviSub on the 642 for several Divx videos from recorded documentaries. Subs were SRT files, with commercials edited. Did LOTS of checking on the original MPG for subtitle synch.
The AVI files played generally OK, though the font color does not seem to be controllable, and there were occassional timing glitches.
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 13:39 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 03:22 -
Philips DVD 642/37 Mostly a Blue Picture
By Shieh in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2008, 12:32 -
First Generation Philips 642 Stopped Playing DVD+R DL
By somebodeez in forum DVD & Blu-ray PlayersReplies: 7Last Post: 4th Sep 2007, 17:57
