Hi,
I use HFX pro v4.6.7 build 34. I use premiere pro 1.5 for editing. Under "effects" tab of
premiere, in video transition I found a folder named Pinnacle. Under which there is only one
transition "hollywood FX 4.6". But there are many other wonderfull transitions which arenot
seen inpremiere. I would like to use all those inpremiere 1.5. Could you please guide me to
the process of doing that? Itried to "user manual" but that did not help much.
Please help.![]()
Hi src2206,
Welcome to the forums.
Have a look in your directory equivalent to: C:\Program Files\Adobe\Premiere Pro 1.5\Plug-ins\
...are the effects located in there? If so, try moving them / the folder they're in into the \Common\ directory that's the next one down, i.e.: C:\Program Files\Adobe\Premiere Pro 1.5\Plug-ins\Common\There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hi daamon
Thank you for your reply. In my default plugin directory I found 2 HFX files which I have copied in 'common' folder. But sorry to say, that did not help. I can still see only one HFX transition in Premiere under Pinnacle folder located in 'effects' tab of 'project window. After placing that transition in the timeline,(only this single HFX transition is usable) when I open 'effect control' window there is a button labelled as 'custom'.Clicking on that button opens HFX editor with all types of transition but I can not import/use any of them in premiere..
Please help -
Hmm... SOrry to here that didn't help. Have you sought advice from the providers of the HFX effects as to where they should be put / how they should be installed?
Also, try searching for / asking your question in the forums at www.wrigleyvideo.com/videotutorial
I don't use those effects, so can't help beyond what I've already suggested.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Hi daamon,
Thank you for your reply. As you suggested, I have joined wrigley VPF. Please feel free to keep in touch.
Bye -
Hi daamon,
Thanks a lot FRIEND. Your link has solved my problem.
The solution is located at http://www.wrigleyvideo.com/forum/index.ph...hl=hollywood+fx
Bye. -
Hi src2206,
I'm glad you got it sorted. And thanks for posting where the solution can be found - it'll be useful for others who have the same problem.
P.S. The link is incomplete, and so will fail. The full link is:
www.wrigleyvideo.com/forum/index.php?showtopic=6916&hl=hollywood+fxThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Hi daamon,
Thanks a lot FRIEND for the correction.
Are you interested in AE? Then check out http://xtreme-is-back.com/tutorials.html (if you have not done already!). Hope you won't be dissappointed.
By the way , do you know any good AVID tutorial source (except AVID FREE DV TUTORIAL -I already have this) ?
Bye & keep in touch.
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 22:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 09:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 17:10 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 16:27
