I have a older JVC camcorder I bought that is not being recognized by my computer. I have a new Toshiba M-65 laptop, XP, SP2. I didn't have a 4 pin to 4 pin cable, but I did have a 4 pin firewire to USB 2 cable which I'm using in the usb port. Could that be the problem? I'm getting the error message "unknown usb device" and "no supported capture device" in Nero and WinDV. Hope I explained that sufficiently, thank you so much, Doug
Yes. Get a Firewire cable and use the Firewire port.Originally Posted by doug696
What the heck is a "4 pin firewire to USB 2 cable" ??? I can't even think why they would even exist....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=9715847956&rd=1&sspagename=STRK%3AMEWN%3AIT&rd=1
Hope the url comes through. I did find out that usb cannot be used for video or so another forum states. Hey, I'm a newbie. Rameletronics has a 6 pin to 4 pin adapter I'd like to buy, do you think it would cause me problems. I have a 6/4 pin cable right now so why buy another. Thanks for your quick responses, Doug -
BTW, what might someone use that cable for for future reference, is it useless? Doug
I don't think that is a USB to Firewire cable. If it has USB on one end, the other is probably mini USB, which looks similar to a mini Firewire cable connector. You are probably looking for a 6 pin Firewire to 4 pin Firewire. The computer is usually the 6 pin end. The extra two pins on a 6 pin cable are to carry power for external devices and are not needed by the camera, hence the 4 pins on the other end.
Camcorder not recognized
By jmandy2010 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 21st Sep 2010, 17:40 -
My Laptop not recognising my JVC DV Camcorder
By topcat0001 in forum Capturing and VCRReplies: 7Last Post: 29th Aug 2010, 11:42 -
JVC mini dv camcorder
By biancoape in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Feb 2010, 09:14 -
Camcorder JVC used as webcam
By wrummmmm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jul 2009, 07:56 -
JVC GR-D750 Camcorder
By didikai in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jul 2007, 12:11
